Hello,
For Bokrand tonearm owners, what cartridge and headshell combination are you using with it?
Cheers,
Cheers,
Sorry off topic but you understand if you have/had one. There are vey few things that I regret not keeping, my red Shamal is at the top of that list!Hello,
Cheers,
Fantastic! Lucky man!A 1994 garaged for eleven years in my home in Rapallo and a hand grenade ['85 Biturbo E] here. No ABS brakes, no power steering, no electric seats, no smog system and no cats, absolute freedom!!!
Cheers,
Horacio
I bought my Bokrand specifically for an Ortofon SPU. I'm using a Classic GE MKII that really sings with this arm, so I'm looking to try a Royal G if I can find a few grand somewhere... View attachment 98234
Nice!! How’s that combo with Bokrand work for you?I am using an Ikeda headshell with the Ikeda 9TT
Very well indeed. I believe the Bokrand has a higher mass than the 3012/II that I used before. The bass is more extended and sounded more impactful. Distortion is lower, esp. at the end of side. Very happy with it.Nice!! How’s that combo with Bokrand work for you?
I also went with wired version. Which pickup will grace your Bokrand?I ordered a DaVa wired arm from Alfred last weekend
will try and compare with the Groovemaster
think the AB arm should fit in the VTA lift, so I just need to swing out the armboard a little to realign from 304,75 to 309mm pivot-spindle distance
it’s a DaVa wired arm for the DaVa cartridge which is a field coil cartridge
Thanks, wasn't aware of that particular cartridge.
it is a direct sale cartridge from the manufacturer in Lithuania, has a one year queue, plus he isn’t taking orders till May 2023 to clear the backlog. It is 3k for the basic and 6.5k euro for the reference plus 1500 for the tube PSU power supply.
some feedback here, thread started in 2020 and developed since
Finally I got around to install my new darling, the Lithuanian fieldcoil cart that´s about to cause a HUGE STIR in the analogue world Based on the Neumann DST principle from 1962 and with fieldcoil magnet and a cactus cantilever tipped with a 0,5 conical gem, it´s in the exotic category I´s a...www.whatsbestforum.com
Zero-Distortion: Visit to Mike Lavigne - Saskia vs CS Port vs NVS, DaVa, Etsuro, Primary Control
https://zero-distortion.org/mega-analog-shootout/www.whatsbestforum.com
I had shitty experience with Garrard 301 and UK 1 man shop too....
