Ah not really looked into it , I know it is an early tube but can't remember the yr.Thanks, will be good to listen to the GEC. Do you know which years your osram was from?
I'm sorry for your misfortuneAnother one bites the dust. One of my T-100s fizzled out last night. For those who want the score card, here are the tubes that have died so far in my Pacific:
1. KR 242.
2. NOS 45.
3. PSVane 101D.
4. KR 100-D
4 tubes in roughly four months. At this rate, this could become a really long list. I’m going to have to create a separate thread for tube failures on Lampi DACs. If it didn’t sound so good, I’d throw in the towel now on my Pacific.
Now this is a bit strange - never heard of case like this but burning so many DHT which are far away from being cheapish (except nos 45) i would seriously think about sending the Pac for the check upAnother one bites the dust. One of my T-100s fizzled out last night. For those who want the score card, here are the tubes that have died so far in my Pacific:
1. KR 242.
2. NOS 45.
3. PSVane 101D.
4. KR 100-D
Did you speak to your dealer? Definately something wrong hereAnother one bites the dust. One of my T-100s fizzled out last night. For those who want the score card, here are the tubes that have died so far in my Pacific:
1. KR 242.
2. NOS 45.
3. PSVane 101D.
4. KR 100-D
In goes the sacrificial lambs for some roasting . The lampis are quite reliable but as in any product lemons are known existI’m trying to see if I can figure out a pattern. If this repeats, I’ll contact LampizatorNA for sure. Put in a quartet of new JJ 300Bs today in my Pacific. Will see how they fare. I have another quartet of the same JJ 300Bs in my JJ SET amplifier and they’ve been very reliable there (knock on wood). I hope this is not like the old joke about British sports car lovers always owning two Jaguars, because ones always in the shop!
Speaking of which, how many people here own multiple Lampizator DACs?
My attenuators are -10dB and they are of standard type: should be connected at the end of RCA cable that goes into preamp. They also have other type of attenuators, where you connect them at a source end. Are you sure you connected them correctly? Also, it might be a burn in issue. In my case, they sound better even with PX25.I tried Rothwell attenuators from DAC to preamp to test the possibility of reducing gain and improving the range of my volume control. They lasted all of 5 minutes! I couldn’t believe how bad they sound.
If you use some resistors in the Lampi try the Audionote silver Tantalum or Niobium range.
cheers
Blue58
Why not use a high quality passive preamplifier, like this one?I also tried Rothwell attentuators and had the same shock as Blue. Just sounded awful. I put it down to the fact I tried the -20DB ones and it was obviously too much attenuation. That said I felt if I went to the -10DB ones they would still be a really bad idea.
That was a good few years back. I have had AN silver tants in my DAC for some years now and they are definitely very good.
I think you need to aim for as little attenuation as possible with the best resistors you can find.
The attenuation to my DAC was made when I was using a tube pre, which could get overloaded by high output from the DAC.Why not use a high quality passive preamplifier, like this one?
KHOZMO - Dual Mono Passive Preamplifier- RCA | eBay
Find many great new & used options and get the best deals for KHOZMO - Dual Mono Passive Preamplifier- RCA at the best online prices at eBay! Free shipping for many products!www.ebay.com
I did and I prefer USB.Anyone compare the USB input to streaming directly to the LAN input on the Pacific?
Not true! And I have and run a tl0 as wellInteresting. I find the USB input on the Pac to be pretty awful sounding compared to the sound I get from playing back CDs on my CEC TL0 transport, which is still hands down the best digital front end I’ve heard in 30+ years of owning dozens of digital products. USB was never designed for high fidelity audio. It’s a jury rigged contrived solution. Chord’s lead designer, Rob Watts, says that USB is the very worst transmission medium for digital audio. His preferred connector is optical due to its hugely better RF properties.
I’m not sure if it’s Roon that’s at fault here. Generally, the higher the resolution the bitstream in Roon, the worse it sounds to my ears. There are of course mathematical reasons why this might be true. DSD injects an enormous amount of ultrasonic noise into replay. About the worst thing you can do to is upsample to DSD, which is a guaranteed way to increase noise. There could be other factors. Modern digital recordings seem to have greatly reduced dynamic range, which I suspect is because of the huge compression engineers seem to like.
To this day, the most dynamic sounding classical music albums I have in my 10,000+ collection at home are the 60 year old Mercury Living Presence series, which used simple minimal miking and no compression. About the worst recordings are the newest DSD ones. I attend the San Francisco symphony concerts regularly and have listened to many Michael Tilson Thomas conducted performances (all the Mahler symphonies). The SACD DSD albums of SFO Mahler are an utter travesty of the sound you hear in Davies Symphony Hall. I noticed often when they record live that they label the mike feeds by the DSD channel numbers, and they use hundreds of microphones, all going into a giant compressor/mixer operated by a recording engineer. The resulting sound bears no resemblance to the beauty of live sound. If you want true high fidelity, look no further than the concert hall!
