Jonyung reported that.
Hi Mike,i'm told that mine are called 'Black Chrome' ($1295 retail per set, all chrome plated is $1200 retail) and don't have any gold on them. whether they have a chrome ring, or black ring, i'm good. these were the last sets they had on hand.
www.revopodusa.com
It is not incorrect, perfectly fine to simply place them under gear. In some cases the results are superior when screwed into the component, but not all cases.I don't even screw my revopods in. I just place them under my gear. I wonder if that's incorrect?...
thank you Ron.Hi Mike,
There has been a recent price increase on RevOPods and all finishes in the USA are now $1395 MSRP. You got in at the perfect time.
Finishes available in USA are: All chrome, All black, Black/chrome ring, black blue ring, black with matte gold ring, Chrome/blue ring black foot.
More sets in stock within about 10 days. We now have a dealer network of five dealers:
HOME | RevOPod USA
www.revopodusa.com
Feel free to contact Elliot or myself if you would like any advice on the setup process with RevOPods.
Thank you!
Ron Buffington
Liquid HiFi
RevOPod USA distributor
How does the “ Tonal Balance “ change.?......Cooler, Warmer, etc.Good on you Mike!
I have been using Centerstage2 0.8 all along ( that's what I have when I acquired the Ref Dac). It gives you all the Immersion effect as we all know, but balancing 8 centerstage is quite a pain initially. It must be much easier with the Revopods given the design differences.
My only hesitation is from users who sold their Revopods, a number of them dislike the "tonal balance" after using Revopods. I guess you gave me the right answer to try them later.
Enjoy
Hi Mike, Your not local "drug" dealer LOL will have a new toy for you to play with early next week . I hope this too will bring a visit from the Holly Motherthank you Ron.
Elliot did tell me i got in just before the price increase, which did make me feel lucky. i'm looking forward to more time getting to know the RevOpods. nice build quality and packaging.
cheers,
Mike
Please do, I‘m curious tooI have a high mass TT with 3 feet using M6 threads so thought it might be worth trying.
most footers are not adjustable, either for height, or degree of decoupling. the RevOpods are adjustable for both variables, and it's suggested that their tonal character is slightly different in different modes for each variable. in essence they are 'tunable'. which i view as a significant asset.How does the “ Tonal Balance “ change.?......Cooler, Warmer, etc.
Thanks.
Mike, I apologize if you already said this, but would you be so kind to tell me what is the total height on both the power supply boxes, server, & dac after installing the Revopods? Just trying to figure for rack shelf height needed-thank youholy mother of god! the decay now goes on forever (if it's on the recording).
took me about 3 hours to install and adjust the 24 RevOpods (6 sets) under the dac, 2 power supplies and server. had to remove my dart pre so i could remove the 'Tana' Daiza under it to allow for the height for the server to stay in it's spot so i can see the cover art. followed 'Stereophonic's' coaching (thanks!) and bottomed each pod, installed them on the chassis, then reversed 5 clicks. once in place i adjusted each footer by feel to have equal pressure. had to play around some as each footer is relational to all the others, so you are going around adjusting them all little by little until all of them are as equal feeling of pressure as possible. i will give it a week then go back and check and adjust them again. not really that hard other than in behind the middle of my rack it's a bit of a twister game for my 'old' body. handled the weight ok with no mishaps. took my time.
i was able to combine the RevOpods with the Dazia on the dac and power supplies. but have not A/B'd it so cannot speak to the significance. not sure i will bother with that (hearing zero compromises in any case, likely helping).
RevOpods are the real deal! at least in my system under the Wadax Ref dac and server. immediate sense of more holographic and microdynamic presentation. noticeably greater emotive and expressive content, greater harmonic complexity and textures. greater coherence and drive, more feeling of ensemble playing and flow. lots of small differences musically helpful.
just starting to explore more music and discover the nuggets of ROI. looking for some bass heavy tracks.
and we know what 'black chrome' looks like! perfect match for my chassis color scheme.
View attachment 89106View attachment 89107View attachment 89108View attachment 89109View attachment 89110
first off, congrats on the 'apparent' Wadax Ref dac and Server! and the RevOpods too!Mike, I apologize if you already said this, but would you be so kind to tell me what is the total height on both the power supply boxes, server, & dac after installing the Revopods? Just trying to figure for rack shelf height needed-thank you
Mike, Does 11.5 cover every piece safely?first off, congrats on the 'apparent' Wadax Ref dac and Server! and the RevOpods too!
11.3 inches, so 11.5 inches to be safe. you are adjusting the gap between the RevOpod surface and the chassis bottom.
the 11.3 is what i measured after my initial gap adjustments. i only measured in the front but the shelf and gear are quite close to 'very' level.
yes; they vary from 11.3-11.4. since the top is rounded it's hard to get a definite measurement so i can only 'sight' it. i guess if you are having to squeeze it in, then i'd go with 11.6 inches. the tops only get mildly warm so they don't seem to need much air space.Mike, Does 11.5 cover every piece safely?
