CH Precision D1.5 sacd transport/player
CKKeung
3,074
3,216
1,410
Hong Kong
Details on CH web site.
The MSRP is CHF 33'900.- in Switzerland (incl. 7.7% VAT),
€34'300 In Europe (inc. Europe's 20% VAT).
The additional pair of monaural DAC boards to make it a full player is CHF/€ 4'800
Reactions: MadFloyd
US price is 41k plus 5k for the Analog output boards if required.
Please find below further details regarding the new D1.5 Player/Transport and its availability.
With an almost identical form-factor and operational interface, the D1.5 continues the established CH aesthetic, fitting in perfectly with existing and future systems. However, internally it is a completely different machine, based around our own, all-new, proprietary transport mechanism.
  • In-house designed and built Mechanically Optimized Reading System (MORSe) disc transport. Massive, ultra-rigid construction, with precision, mounted and critically suspended motor and laser assembly.
  • CH Link HD, AES/EBU, S/PDIF, and TosLink digital outputs mounted as standard.
  • Fully compatible with SACD, CD, and MQA CD discs.
  • Optional dual-mono DACs and Sync IO board allow users to specify or adapt the unit for uses as a transport or player, with or without external clocking.
  • On-board decoding now employs a state-of-the-art PEtER spline filter algorithm for CD Replay.
  • Users can configure digital outputs to optimize replay of MQA discs with an external MQA capable DAC, avoiding on-the-fly sample-rate switching.
Launch:
The D1.5 will be making its public debut on November 5th, 2021, simultaneously at Acoustic Gallery in Paris and with Zephyrn at the Tokyo International Audio Show.
Availability:
We are expecting to ship initial orders week 46, w/c November 15th, 2021
Launch:
Availability:
This is great news.
I hope that there is more in-depth explanation of the diff between D1.5 and D1.1.
Currently our impression is that the new model is launched because Esoteric sacd transport mechanisms are no longer sold to other brands.
Does D1.5 have any other improvements?
Hi. We are excited to announce the D1.5. The D1.5 can be configured as a one box player that plays CD/SACD/MQA encoded disks by adding a pair of Analog output cards, or as a transport feeding our C1 through CH-Link HD or any other DAC through it's digital output card (AES/EBU, S/PDIF, TosLink). Highlights of key improvements in the D1.5 are:
1. Improved Mechanically Optimized Reading System (MORSe). While the Denon/Marantz mechanism is now used, dozens of proprietary improvements are made to dramatically improve performance.
2. Plays MQA encoded discs. As a single box player, the D1.5 will completely decode and render an MQA encoded disc. This is possible through improvements made to the on-board computing capability of the D1.5. The D1.5 has been certified as an MQA capable player. Additionally, with this improved computing capability, we are able to implement our proprietary Spline filter for upsampling and our digital filter as we use on our C1 and i1.
3. Improvements have been made to the power supply of the D1.5 making it even quieter than the D1
4. The mechanical improvements made to the transport mechanism improve the D1.5 performance as a transport.
All, a few more details for you on our new D1.5.
The MORSe consists of a heavy brass module, weighing almost 1 kg, on which the optical pick-up and disc drive motor are precisely assembled. This unusually high weight allows us to push the mechanical resonance frequency of the module several orders of magnitude lower than in most other transports, while ensuring an ideal counter-weight to the torque of the spinning disc.
The complete module is isolated from the rest of the chassis using four alpha-gel isolators, fine-tuned to filter vibrations all the way down to AC mains frequencies. This prevents vibrations generated by the spinning of the disc from reaching sensitive electronic boards, as well as low frequency vibrations originating in the power supply or chassis disturbing the accurate tracking of the laser mechanism.
The disc clamp is made of lightweight PEEK polymer, which provides optimal grip and dimensional stability, ensuring slip-free transmission from the direct drive motor to the disc.
The chassis holding this crucial sub-system is a 2 kg rigid aluminum structure, directly coupled to the heavy base of the D1.5, which is in turn directly coupled to the supporting surface by the latest implementation of our adjustable spiked grounding system, creating an ideal mechanical ground reference for the rotating parts.
Optical disc formats, manufacturing techniques and materials continue to improve, those improvements delivering a significant increase in musical performance. With the MORSe – in the shape of the D1.5 player/transport – those musical benefits are more apparent than ever before, offering a substantial upgrade over the D1, both as a player and a transport.
Thanks rsorren1 for the detailed explanation!
BTW can D1.1 be upgraded to D1.5?
If yes, is the upgrade worth the cost?
Thanks again!
Thanks again!
In the US market, there is a trade-in / trade-up program for D1 owners. Our dealers have the details. Check with the dealers in your geography for the exact details.
I’ve now listened to the D1.5 in my system for about a week as a one-box player and as a transport connected a C1/T1/X1-D. As a one-box player, it is a big step forward in presentation when compared to the D1. MQA encoded disks especially sound great! The use of our Spline filter and digital filter in the D1.5 have improved the sonic presentation in every way when compared to the D1. As a transport, I’m hearing more details in the presentation than with the D1. The power supply improvements and improvements to the transport mechanism mentioned above are the likely reason for this.
Reactions: Bogan88 and CKKeung
Great news!
many thanks again!
Reactions: Scott Naylor
Does the new transport control and play discs using their app?
Will the app shows the track list and allow users to choose any desired track directly and play it?
Hi Jeromelang. Yes, the D1.5 can be controlled using either the supplied remote or the CH Precision control app (D1 too). Our app does not show a track listing, however, one can directly choose a track to play using the control app. To do this, load a disc. The total number of tracks appears on the front panel of the D1.5 and is duplicated on the control app. If you select the D1.5 on the left side of the control app screen, then touch the number of tracks on the control app screen, you can choose any track that you would like to play directly. I usually have the CD/SACD/MQA disc holder in hand and select a particular track that I would like to hear. Hope this helps.
Reactions: CKKeung
Thanks, that is very, very good news.
The conventional way of cueing up any desired track to play on an optical disc player is fraught with several sonic compromises. Different ways of cueing up the same track to play will simply yield vastly different sound. And having lived with 3 sets of esoteric optical transports for the last 8 years, I just about had it with their finicky servo behaviour.
If CH's direct access method through the selection of the desired track by the app works the same way as how Sony's bluray/dvd players do it, by not leaving a memory imprint before play commences, then you obviously will have a big sonic advantages over all other conventional optical transports.
I look forward to going down to the local dealer to verify this.
