The spec sheet says 2002b. So it should work with Linux.What does you spec sheet say? Does it give the FW number? if not just contact Lukasz about reflashing. its fairly easy but you need to open the chassis and use a windows computer.
I checked it, when I ordered the dac, and was told, that the switching between chipless DSD512 and R2R is fully automatic in GG2.Azizz, please post a picture of your Dac, front and back.
EDIT: found the pictures here, https://www.whatsbestforum.com/threads/golden-gate-2-reactions.24388/page-4#post-513809
It seems you need to actively engage DSD512 chipless module. Not sure if that is pushing in the faceplate button, as that is usually to switch between USB and SPDIF input...I always had Vol CTL Lampis since B7 (you use the remote control), so am not sure how this is done on your Dac.
Thank you, I will try that, when I get home. I was sure, Lampizator dacs only support DSD via DoP, that is why I've always selected DoP.Azizz - On your browser go to http://myantipodes.com. Click on the manage button. Click on settings and then on the Roon Ready icon. Make sure the DSD Support window has Native DSD selected and not DoP. I may be wrong, but I believe DoP only supports up to 256. The screenshots you posted in previous messages are identical to what I have. I have an older version of the Amanero firmware that only supports DoP up to 256. Hope this makes sense. Let me know the outcome.
not at all. they support native. Dop cant support 512Thank you, I will try that, when I get home. I was sure, Lampizator dacs only support DSD via DoP, that is why I've always selected DoP.
Native rate playback beats upsampling...to me at least.It worked. I have DSD512 support now. Although, I am not sure, I liked, what I heard.
Mr P, thank you very much!
