Hi, lowering the bias is the only way I know and keep the configuration. The one gent I knew had a pair used WE 90's vintage 300b's- he had an inventory ( lucky guy).
These WE's fared quite well but still biased lower than he would of liked. I liked these biased up quite high but at that point with Russian or Chinese tubes you are into failures and early mortality. This design is at least 10-12 years old and I don't believe Allnic has a current amp in this configuration for this output tube. It is asking a lot of the 300b from the current mfrs.
In fact, Allnic have gone heavy to KT150 types and using the 300b only as a single tube per channel in more conventional config with a big drive cct. in front.
Nice sounding amps - I like to go to 1 tube per channel 211 or 845 for a little more grunt if I need it in a SE design and take the +/- on the "sound" character over the 300b. That's just me. I would call David Beetles the distributor he is very customer focused. He can ask Mr. Park if there are other options or recommended tube choices.
Best of luck.
Best of luck.
