I guess many people still admire Taiko Extreme Server. So they are not excited about Wadax. They didn't appreciate Wadax at all, even Wadax Reference DAC. Prejudice is a bad thing.Look fwd to it getting 5000+ posts here.
very high end music servers deserve and require a level of technical handholding for customers that exceeds any other high end product. hard to imagine any hifi dealer being truly capable of the degree of support they require. therefore; it is on Wadax to prove they are up to that task for this server.
the problem for Wadax is not a 5000 post thread. the problem is that it's easy for potential customers to observe the other-worldly level of support and continuous passionate engagement from Taiko for the Extreme and it's owners. the bar is impossibly high. and this is assuming that the product makes the performance case that it's equal or better.
maybe Wadax has established a presence and support level for their products that does indicate they are up to this task. i've just never seen or heard about it if that is how it is.
and then are the implications of the potential of TAS as a standard setting software.
lastly will Wadax appeal to the DIY computer audio group to get some moral support and benefit of the doubt?
so it's not that there is not excitement about this new ultimate server; only that it's not a dac or transport......and not plug and play. so there are huge hills to climb and gravity to overcome. it will have to ring the bell pretty hard the first go to get over the hump. and maybe it will. i know i'd like to hear it, and hopefully when Audio Shows start again i will have that chance.
as an aside; i wonder what they were thinking with the whole design and look of this product? i keep trying to like it, but so far it's not working. maybe in person it pulls you in.
Well I'm not a computer expert, but how do you run Roon (I assume they will use it like the Atlantis Server) with an ASIC chip?
I'm afraid that's not so easy. Roon Core can only run on X86 processors
