Like Leif. I dub from a modded A80RC to a Nagra IVS and I have not be able to hear any difference in my system.
IMHO we can´t ignore the Ampex ATR100's and ATR102's in this top list. Although I have no experience with such machines, many experts consider them to be the top.Leif is 100% correct - all those opamps in the signal path are detrimental to the sound. A820 is indeed the pinnacle of R2R development... when it comes to its mechanism. But I will take the discrete circuit any day, and for dubs I will use the tube head preamp as the source.
Wish I could get a mod like that on my Otari.I dub from one MTSL modded A80RC
best
Leif
If I were to plug in a SACD player and record a disc on a calibrated machine then why would it not at minimum pickup the same level of playback quality and range?
How much impact does the sending source have to the overall accuracy of a duplicatuon. I get anything lost is lost.Because every tape machine has its own sonic signature, that it will impart on the sound. Some are less intrusive, and will give you a near-perfect copy, others will damage the sound in very obvious ways.
Unfortunately, the severity of that degradation does not correlate to the brand recognition or the machine price.
It is the same old weak link situation, you will be hearing mostly the worst component in the chain
If in truth your career was in audio equipment design and you are intimate in your knowledge, then I degress. I accept your answer.Hardly a cop out... more something based in hard experience. Having designed pretty much every item you mentioned, I can assure you that bad job can be done at any stage along the way. OTOH, designing them well is also not exactly rocket science. However, other priorities often enter the equation - such as cost, marketing focus, darn features, etc.
Your Otari/Studer example has no simple answer, as not every Otari, and not every Studer are the same. In my particular case it is easy - I use the Otari with an external head preamp as the source, and record on Studer A80 (there are other options here too). Definitely NOT the other way around, but my case is just my case.
2 MTSL A80RC for this very reason....
(...) From my understanding today’s tape is far superior in playback from previous generations including longer life. (...)
