I've just placed an order for this amp. I'll post my impressions on this thread. Thank you.
I hope it was a cheap option...I predict a poor match...
Now you tell me!I hope it was a cheap option...I predict a poor match...
I posted a few days ago in the What is your favorite 845 tube thread. My Black Shadow return from a total rebuild in a week or so. I only have Shuguang and Pysvane hifi tube. I want to try a good 845 and was wondering about the linlai WE tube and the Psvane ACME. If anyone has tried them, could you post your thoughts in that thread. I have not written off Elrog, but I don't want to spend $2000 if the others get me most all the way there
Thanks, Rex
Based on many attempts at mixing tube and SS, class D etc.Based on price, your own experience, or the rep of decades-old Crown amps?![]()
I am happy to be wrong...
No problem....Nice! Please could you share any more detail on your line level crossover either here or pm. Thanks v much.
No problem....
for the Mid-High is use a simple 6dB high-pass and calculated the cap by using the input impedance from the amplifier
for the bass it's a 6dB low pass, calculated that the resistor is very low that I have less decrease of the signal
both corner frequencies are layed at -6dB for the slope
Feel fre to contact me by pm
I got cold feet and cancelled the ordered.Based on many attempts at mixing tube and SS, class D etc.
How do you do the gain/level matching of the different amps?Well i achieved superb results with TAD CR1 at 250hz with HF CAT JL5 and LF Nord NCORE NC 500 MK II ...
Oh, well if it was cheap maybe the experimentation would have been fun. If you don't have enough umph with just the Allnic, then find an old VAC 70/70 to put on the bass, which will match up a lot better and can be found for 3-4K. I had a VAC 30/30 in the past and that was a good sounding amp with quite robust bass power and control...I would expect the 70/70 to be similar. Other options would be the Antique Sound labs Hurricane or their 845 PP amp (60 watts).I got cold feet and cancelled the ordered.
I've also found that by toeing out the speakers I get more woofer contribution.
Or get a NAT MAGMA-heard them in Munich some years ago, sounded really dynamic and nice
Magma New ist 170 wpc![]()
Yes am aware. But whether he requires that much power is not clear
The Ocatve stuff is very stable if you want Tubes or CATYes, a NAT would work (I like NAT products...had their Plasma preamp a while back) but I was talking about biamping and still using his Allnic on the mid/high horns and the VAC or other strong PP triode amp on the bass. I was also thinking cost conscious.
