Someone listen this cartridge?,Top of Soundsmith below Straingauge?
Have owned a plethora of cartridges over the years, currently a Koetsu Coralstone and just previous a Ortofon Anna. I listen to these MC's with a Kuzma 4 Pt and Aesthetix IO Eclispe. I have owned the Strain Gauge(SG) for at least 5 years and it will remain in my system. Overall prefer the SG above all cartridges I have listened to in my system. It possesses remarkable speed, detail, attack and extended frequency extremes. All of this with a warmth and organic rightness that creates a late night music addiction. My most recent cartridge purchase was the Coralstone 2 years ago so have not listened to some of the more recent top end offerings from the likes of Lyra, Air Tight, etc. And while I understand Peter does not condone modifications to his products (understandably so, no one knows his products as he) I have made several modifications to the energiser which has improved the SG, in my view, significantly. I would encourage all current (and future) owners of the SG to remove the wall warts and replace with a Peter Downs, Paul Hynes or even a Sbooster BOTW power supply. You have not heard your SG until you have.Peter has both carts.Depending on the music he is listening to his use is %75 Soundsmith Hyperion to %25 Strain Gauge .Over the past year I have read about Soundsmith and the Hyperion.Given the theory behind the cart is there anything out there better sound wise??
JaxDr
Stump,Thankyou for your input.When you add your phono stage (Aesthetix IO Eclispe phono stage) to the carts you have compared what is your view of the importance of a phono stage . I would like a hiend phono to match my turntable and future cart or try the Strain Gauge ?View attachment 51473
I believe the context of Stump's question above was greater than just a SG and including MC's. Thus my reply regarding a phono stage.The benefit of the Strain Gauge cartridge is that there is no need for a phono preamp. So that is one entire stage of filtering that a Strain Gauge cartridge signal never gets adulterated from.
Hello spiritofmusic,Jaxdr, you own SG? 5 or 6 stylus? Impvd LPS from stock wall warts?
Jaxdr, are you based in the UK? I was an early adopter of Peter's AA LPS, and the SG w it is night and day an impvt over the stock wall warts, and greatly impvd over the Vinnie Rossi Black Lightning batt psu I was using prior to the AA LPS.
The only caveat is the need for a solid 80-120 hrs of burn in, the SG via AA LPS is pretty grey and thin until the burn in was complete. However, what didn't help in my case was a brand new SGS-6 stylus in addition to upgraded energiser and the cold AA LPS. All cold w zero hrs on the clock. And a whole bunch of brand new analog upgrades incl new tt motor psu and arm mount/arm unipivot points/tonearm lead.
So the worst combination of cold components to warm up and meld together. Indeed, 25 hrs in, I was tearing my hair out as to how poor everything was sounding. Fast fwd 100 albums' worth of burn-in later, and my analog was showing proper signs of being the best it had ever sounded.
A year later getting used to the fully bedded-in AA'd SG, plus optimising the rest of my analog rig (critical benefit of 180kg slate stand and Stacore pnematics isolating a mere 20g of SG cart/carbon fibre armwand), and I can say in my experience of owning and using Roksan Shiraz, Transfiguration Temper Supreme and Orpheus, Lyra Skala and Parnassus, ESCO-modded Zu Denon 103 carts, via Roksan, Clearaudio and Tom Evans Groove/Plus/SRX phonos, the AA-pwrd SG is in a different league.
Re 5 versus 6 stylii. Initially I was a bit unsure of the 6 compared to the 5 which was the stylus I bought. However, as things opened up, it's shown to be the more accurate detailed choice, and really superior to the 5. But requires greater dedication to setup, esp azimuth.
Good luck w the AA LPS. Be patient, and you'll be rewarded w the best SG sound yet. Mention me to Peter, his SG and Nat amps customer in the chapel in Norfolk.
Jaxdr, how did you find out about the AA LPS? It's only a custom order, and Peter is not exactly visible online.
Indeed, had I not been an original customer of his, no way would I be coming across this.
