Myles, can you help me with my turntable![]()
I'm still going through the stack of records I haven't heard yet but bought over a year ago, some real gems in there. Since spending weekends in Santa Cruz for a year at the new place, haven't been back to Amoeba in Berkeley for over a year, no new acquisitions for vinyl. In Santa Cruz, I am all digital with a Mac Mini Itunes server type thing.
I will get my back pack and bicycle to look for LP's in downtown Santa Cruz some day, but every time my wife finds a new vinyl haul, she gives me grief. Have had some nice snags at the local Goodwill, however. I prefer a nice one dollar vintage record to a modern remaster any day.
What's up with the table Sam?
is the ET2 hesitates to travel the final 1.5" or so of the groove. I've consulted the manual and have cleaned with anhydrous isopropanol. During the week, I'll give Bruce Thigpen a ring and inquire about using acetone; otherwise, disassembly and proper cleaning may be indicated.
Just got a precise pressure gauge...I'll assess the pressure from the Wisa as soon as I source the proper fittings.
The Peanuts cartoon reminded me when Tower Records used to be on Sports Arena Blvd. in town...one would encounter all manner of people -- very cool.
Have you cleaned the inside of the bearing with ROH too or just the arm? I assume you're using an in-line filter between the arm and the pump too?
If using a filter, it may be partially clogged as well. I'd inspect the entire length of tubing, replace the filter, and clean the arm and manifold surfaces thorougly. A final thought is that the Wisa pump has lost efficiency and needs replacement.
Since the arm travels most of the way across the LP, it most likely seems as if there is some dirt/deposit on the arm tube at the point where it would impede travel through the manifold.
Lee
I've never disassembled nor assembled, for that matter, this arm. Hopefully, sufficient litz wire will be available so no detachment from the arm will be necessary.
Is there a trick way of pressing-out/sliding the manifold from the sleeve? What grease is recomended to lubricate the O-rings prior to re-installation?
Thanks!
All you have to do is take of the cueing mechanism which is one screw. After that, you just push out the spindle. There is plenty of wire there so you won't need to unsolder anything. As for O-rings and grease, I have no idea what you are talking about. There are no O-rings on my spindle and grease is the last thing you want. Unless you have some version of the ET-2 that I don't have, there are no O-rings on the spindle.
Hi Lee,
GREAT suggestionI suspect there is some type of deposit on the arm tube/spindle; however, vigorous cleaning with alcohol and an electric toothbrush yielded only temporary improvement
