no tube rolling for me. I still have a stock of 'expensive' tubes from my Lampi encounter, don't need to add any more. one main attraction of the ML3 was to leave that behind. I like it as it is. now if Vladimir from Lamm recommends a different tube that would be different.
Lamm aficionados, please clarify one thing for me:
I was always under the impression that despite making most sublime music in virtually every system, Lamm has a "darkish" character, and that the highs were not fully extended on all systems and combinations.
First, is this correct, or is this myth? And if the highs are not fully extended, is it true for both amps and preamps, or only some?
Thanks
Mike, still curious re yr move to SETs as a “parallel” listening experience.
Can you imagine using the Lamms predominantly on the part of yr collection that you feel they’re most suited to?
Ie on material that benefits most from the reflective, “interior lit” sound that SETs are really good at, vocals, piano, strings, small jazz groups.
Or can you see yourself listening across a wider swathe of recordings to get an “alternative illumination”, pop, big band, symphonic, 80s synths, electronic/dance.
For me, going first the the Hovland HP200 tubed preamp a decade ago was my first taste of this alternative, interior lit view on music, taken all the way by going Audion SETs 845 monos, and now beyond all the way w my all Nat tubes amp chain, 70W 211s.
For me I’m never likely to swap the inner lit/reveal of SETs for the floodlit uniformity of SS.
What brand of fuse would you recommend, Ron?![]()
Mike, Congrats!
I have heard Lamm gear turn the most sterile, un-listenable speakers into something that sounds like music!
Obviously, Lamm will add a lot of that tube texture and harmonic richness that all of us tube lovers crave. Yet I also remember (possibly incorrectly) that you always strove for "neutrality" in your system.
What is your philosophy for mixing and matching various components to get it right? Where do you like more "neutral" and where do you like more "warmth" and harmonic integrity?
Thanks
Mike
you got it right on. There is no need to roll tubes in the ML3 (although I must admit I do use an NOS pair of Telefunken ECC803S to replace his 12AX7)
BTW, IIRC there is also a Lamm LL1 for sale in that same place![]()
Lamm's aren't dark, they might seem that way to people used to hyped top ends, wether from their electronics, cables or both.
david
Mike
david
I haven't listened much to Lamm equipment but I know exactly what you are talking about. Some people are obsessed with brightness, not realizing it is just their coloring of the music.
