hello Tang,
here is a picture of my 2 Studers with the direct head outputs; both installed by Ki Choi. the left side has the modified top cap with the head switch mounted on the back side of the top cap. the right side is 'nude' and that switch is not yet mounted on the top cap. yes; Ki thinks it is preferable to run the cables on top as far as signal purity. but my recollection from our talks about this is that Ki has not actually listened for the comparison, it's just his sense (which I agree with). as far as aesthetics, i'm good with it and have never felt it detracted from the Studer look.
the wires on the left side are not properly located as of this picture since we had been inside those top panels and the little sticker wire holders are not currently installed. I have just not got around to buy a couple more at the hardware store.
I have no plans to ever change this approach.
.. . I would not have known there is an amp next to the head in the a820. . .Tang
Are you interested in why it is there?
Mine is wired internally with a separate internal board. Personally IMO it is more aesthetically pleasing
Interesting photo Mike.
It's a shame it's not in a thread titled head direct out on Studer A810, A812 and A820.
Anyway, here are my questions.
Is your head out cable shielded twisted pair or coax?
How much did the head resonance change when you connected it?
Are there VU meters on the front of the outboard tape stage?
Can we see a picture of that?
Lastly, if the reason you leave the top cover off of the headblock is for easier azimuth adjustments, the factory mod for that is quite simple.
If you send me the cover, I'll do it for you at no charge.
Mike,
You DO need meters - they are "way cool" - and a lot of Audiophiles listen with their eyes!
Charles
I am personally very satisfied with the look of the wires running on the outside of my Studers, but completely respect and understand other's preferring it tucked inside.
maybe if it's just tucked inside and there are no junctions (including no plugs and still continuous cable into the outboard electronics) or added bit's in the signal path there would be no effect on performance. OTOH if that wire is connected to plugs on the rear panel there likely is some loss of that minimal signal with that added connection as there is with a phono cable.
It seems like the cleanest signal is achieved by your setup...having the wires run directly from the head block to the pre amp. There are no junctions and the wire's opportunity to pick up stray noise is limited.
Hello Mike,
It appears our machine is a bit different. Mine has this trapezoid black plastic button that acts like a tape tensioner. See pics when I pressed. If this mechanism is taken out maybe I can route the wire through it...just my silly thinking. I can use the VU meter of the Doshi instead if redo the direct headout. Nick will arrive 18 next month. I have seen pics of his work at Myles. Although couldn’t do the internal wire routing, but the work looks pretty neat. Will see how it goes next month.
Kind regards,
Tang
. . . Mine has this trapezoid black plastic button that acts like a tape tensioner. . . Tang
. . . no need pair of UV meter fix to amp unless you want to watch when playing. . .
