EML recti was weak with less bass and bloat as compared tohe special KR recti. Bill and I sold ours off immediately after listening to the special KR recti. Which is now what most like Christoph etc are using.
The 101D replicas are not good enough at this level. They are dynamic and detailed, but they lack tone, are lean, and are relatively flat planed as compared to the better valves.
I would suggest borrowing KR 242 (which, if it works with the gain, will jump performance up multi times), KR PX25, and the special Lampi EML 45s from Lukasz for a trial. Of the latter two, one or the other works better in most systems
Interesting. And that configuration is likely the most challenging for the Vivaldi. I'd try it with Dual AES from Aurender and the Vivaldi DAC I know needs to on for about 2-3 days to warm up properly and sound best...I'm guessing these two items may improve the "meat on the bones" aspect...
Regardless of DAC, AES/EBU is likely to give better results than USB of you have the choice (...)
Our settings are identical.....Interested to hear what the NUC/ROCK does sonically, if anything.......
I don't know just yet. I need to listen more to draw any solid conclusions. I have certainly liked what I've heard - certainly enough to warrant further investigation. I've been in this hobby long enough to learn that it is not the things that you like at first listen are essential for long term music satisfaction. I may miss the uncanny palpability and midrange weight that GG provides longterm.
I need to get my Lampi up to spec before any further comparos. I'm leaving for 2 weeks in August for an Elbrus expedition (the highest peak in Europe), so will probably drop my GG to ?ukasz for updates then.
I'm running the WE101D replicas and the Emission Labs recti.
I had both DACs connected directly to the D'Agostino Momentum Stereo - which is my main amp now. Vivaldi was set to 0.6V output, so most listening was done with 0dB to -6dB digital attenuation.
Are you going to drive D'Agostino Momentum Stereo directly? IMHO we need the preamplifier to get the best of it. I really like the Momentum Stereo a lot, but dislike the price of the Momentum preamplfier ...
The Golden Gate has a built in analog preamp, so I have no desire to insert a second one inline.
I'd investigate an ARC REF 6 to pair with the D'Agostino (+ Vivaldi).
I was glad when I read this report, because it validated the D'Agostino + ARC combo.
Francisco (& Adam)
LA Audio Show 2017: D’Agostino muscle, Audio Research glow, YG finesse – an intoxicating mix
I see no reason the same combo wouldn't work great on Adam's Q3, or your XLF!
cheers,
alex
I have listened many times to the Momentum's driven by ARC REF5, even my REF40 in my system and the REF10. Good sound, no doubt. But when the Momentum preamplifier was inserted in the system, the coherence was such that electronics are not SS or tubes anymore, they just disappear. I noticed a similar effect when I had the ARC REF40/REF750 in my system. An hybrid preamplfier / amplifier combo can sound great, but most of the time have a clear and noticeable sound signature.
I remember Michael Fremer reported something similar in his Momentum's review.
Do you have any information on the topology of the output stage of the GG? What is exactly the model you own?
FWIW about 15 years ago I drove my Krell 750 mono amps with an ARC Ref 3 Series lll and the sound was terrific IMHO. That was back in the days when Dan was the man
Careful Steve, Kingsrule will be along soon to remind you that this is a Vivaldi thread!![]()
Worth a read:
http://highfidelity.pl/@main-759&lang=en
"The Network Bridge outperforms Rossini and by a large margin."
"The Stream 820 board was chosen because it offers wireless Wi-Fi and cable network connections. This is a newer model than the one used for Rossini – the latter feature Stream 800."
My VUP has the stream800 board in it. According the the version menu in the iPad app. I wonder if the VUP is about to go through another upgrade soon? I just asked my dealer...he happens to be visiting dCS in the UK in 2-3 weeks...
How can he compare the Network Bridge to the Rossini? The Network Bridge does not have analog outputs and the Rossini is a DAC ...
It would be great if reviewer would physically look at both boards to see if they are interchangeable....
Looking at both boards on Stream Unlimited site, they look very similar....
