Our mind is open. We are just not believers in learning about paranormal.
As it happens and to follow up on Bob's question earlier, someone asked me about this measurement the good folks at Shunyata had run to show effectiveness of power cords:
https://www.youtube.com/watch?v=4qCK--lRFd0&feature=youtu.be&t=28
I ran the same test with an outlet right next to my service panel:
http://www.audiosciencereview.com/f...s/a-c-isolation-transformers.1430/#post-37612
So I actually get a higher rating than what is in the video (1.5 kamps versus 1.1 kamps). But then I make the same measurement at the outlet in my loft:
A massive drop from 1,500 down to 270 amps. As you see, there is no getting around simple laws of physics which we should all know. That messing with the last few feet of wire can't be done absence of what goes on in the other 50 to 100 feet. BTW there are some issues with this measurement which I touch on in my post on ASR Forum.
Anyway, since you have that open mind, would you run the experiment I have outlined for Tom and Micro? That is do a simple blind test for a week to see if you can tell your power cord from another?
