A shout out for Vitus class A. The SIA-025 is a complete integrated package to consider.
can't see a 25 watt Class A amp being recommended for lots of power and difficult impedance
I agree.can't see a 25 watt Class A amp being recommended for lots of power and difficult impedance
Thanks!iaxel what is the impedance and sensitivity of your speakers ?
The Sim Audio 700i is indeed a very nice integrated, i did consider it for myself at some point but depending on your speakers i'm not sure if it will drive them properly.
In what country do you live for not having a Rowland distributor ?
Thanks!
My speakers are measured at 88dB and 4ohm nominal (some lab measurements suggest they should be 2 ohm nominal), but they drop to 2ohm in some mid-high frequencies.
I live in Israel.
The S1 mk1 is an easier load than my speaker. I actually heard it pushed with a 30W class A Luxman and it sounded great. The same Luxman was not enough on my speaker.I drive Magico S1MkII's which are 86db and 4ohm nominal with the Class A Vitus in a medium sized room; have never felt the Vitus lacking or running out of juice. I used to have a 300W (Class A/B) Hegel with very high damping factor previously (which BTW is an amazing integrated itself for much much lesser $).
P.S: I would, though, like to try the Gryphon Diablo at some point; unfortunately Gryphon still doesn't have US distribution!
I've got the Absolare, Ayre, Ypsilon, Rowland and Devialet on permanent demonstration at our premises in Stockholm. I used to have the Gryphon Diablo 300 as well. I'm also carrying CH Precision, where the I1 will hopefully arrive early this year.
All have their virtuos.
What are you looking for besides the ability to drive tougher loads? What does the rest of your system consist of?
All the best.
/ Marcus, Perfect sense
I've noticed there's a cheaper Vitus than the SIA-025, the RI-100, which is 300/600W into 8/4ohms respectively. How does it compare to the SIA-025?
Consider the Boulder 865. Great performance into lower impedences.
I've been asking myself this question lately also to maybe keep costs down for another system. But more like $25k so you can put absolare and agostino (used) in the mix..
I have the cth8550 and love it, drives my WB just fine.
My list would be Diablo 300, absolare, agostino, ch precision, nagra classic, technical brain just released a new integrated, no idea what it's like.. so many interesting options.
Would love to hear them all...
Really? TB stuff is f***ing incredible sounding gear. I was lucky enough to demo their zero mono's while I was overseas several years ago and I still remember how they sound. I am surprised they are not well known here in America.
