So we know and IEC PC is down 5dB and the Shuynata is down 15dB?
We don't have actual figures. Basic twisting pair with 6 turns per foot will provide 13db, but Shunyata probably was able to get in a few more turns so I said 15db. But some Shunyata power cables are shielded, which can increase the performance to say 30db, but even as high as 70db depending entirely on what it's plugged into. You have to keep in mind however that the power conditioner may be much more effective in some different ranges than the power cable, but assuredly have decent overlap. And both are more and less effective depending on the frequency.
IEC PC could be as low as 0, 5 was probably too generous. The wires essentially run in parallel in them.
But you're missing the point by comparing the attenuation numbers, because you're overlooking the fact that they're cumulative. Nothing changes that in this example. And nothing changes that a cord with no turns per foot cannot attenuate as much as any cord with any turns per foot. So, yes, we know that the Shunyata cord will be an improvement but it's subjective as to how the audibility improve is, just like the power conditioner itself is subjective in the audible concern.
