They are a highly strung bunch for sure!Things crashing over at the wam on the fuse thread somebody started.
Buy them from us?!
Anyone soldered thier fuses in? I know it sounds mental but will sound better imo.
Hardly surprising given the Rabidly Objectivist Cabal there! Perhaps you might start a Mook thread for a little further sport.
Hello Blue58 and all, Glad I could be helpful. As for fuse directionality I was told the " Flow through" should go exactly as you read it... So the " S - R" is "Left to Right".
For the Lampi I spoke with Lukasz and asked him directly which way it went for both the B7 and the TranspOrt and he told me : "While standing behind the unit, the flow runs from Left to Right". So that makes it easy... If you're behind the unit the fuse goes in as it naturally reads. This obviously kept me from trying both fuse directions although if someone was indeed curious enough to experiment I would be interested in the results...Hope this helps.
Thanks Lissnr, confirms my thinking, as long as they are manufactured with directionality in mind.Hello Blue58 and all, Glad I could be helpful. As for fuse directionality I was told the " Flow through" should go exactly as you read it... So the " S - R" is "Left to Right".
Oh please do, I will sign in again for that for sure.... They need a good lampooning over there!Hardly surprising given the Rabidly Objectivist Cabal there! Perhaps you might start a Mook thread for a little further sport.
Buy them from us?!
Anyone else got the SR blacks installed yet?
Cheers, Roger.
That we don't know.Do audiophile fuses provide the same amperage protection as the OEM fuse it replaces?
Not sure whether I mentioned but there is a new Black Fuse out by Synergistic Research. Will acquire a couple at some point.
