That is the beauty of explaining clearly.The fault is obvious.Let me explain clearly. If everything sounds good,it's a filter. Iif everything sounds bad, it's a filter. It pains me greatly that somene owns an amp that sounds as he describes under the guise of "fidelity tothre dource." If you have to listen to that throw it in the trash and go to a concert.
Seriously.
I thought about whether I would regret dipping my toe back into this quagmire.....we will see. I just could not resist Tim's tease.
which 'many people' might that be?
I've not yet met anyone who 'like's the sound of digital better than analog (vinyl or tape)' who has heard SOTA of both. which proves nothing.
one would need to be interested enough in ultimate music reproduction performance to actually make the effort to hear SOTA of both in a place where both exist. and how many of the 'many people' have done that?
No Frantz i have not. I said if it sounds as he describes. Would you be interested in amp that sounds "unvarnished and deadpan?" I have however heard that argument many times and always find it ridiculous
I have written about this many times and as you, consider it *the* most effective way to test amplifiers for transparency. They have tested countless amplifiers this way. Very few have achieved transparency. One was the Bryston that you mention and the audio was Audio Research from my post back in 2011:
Real music is colrful. If your device is not colorful, it distorts. Yes I can tell from measurements when an amp will sound the way he describes.Some design with the conscious intention to add coloration. The coloration is by design, no mistake. Bruno designed his amps to be devoid of coloration. And he can back up the results with the stellar measurement data.
However manufacturers of tube amp or SS amps designed to color, can also backup their results with measurement data as well. Although they usually don't, because it doesn't look pretty.
See the problem with your view here is he can backup his claim with real data, when yours is solely based on personal emotion.
Like your assessment that DSD is better than PCM.
That can be backed up too. Have you ever heard DSD before?
It may sound better to you, but on the technical level PCM is superior, at least as several technically inclined people here would argue. So yes, your assessment appears to be based on personal emotion, while you claim to be such a technical person who doesn't want 'colorations'.
Unfortunately I have no more data about it. The author of the test mentioned it in a swedish forum.Was it a tubed amplifier with an output transformer? Such ARC amplifiers had typically 1 ohm output impedance. Any real load would create significant FR deviations.
Real music might be colorful in a way the recording isn't. Adding that color is a color, but it will be a persistent color as you have already referenced which isn't real. So in that circumstance a device without color might still be a wonderfully accurate device which you would remove.
