Then I would say you did very well at the Lycee. I wouldn't ever embarrass myself by openly writing in French.
I have had plenty of 'embarrassingly bad' conversations with taxi drivers in Paris...
I have had plenty of 'embarrassingly bad' conversations with taxi drivers in Paris...i am used to it.
Yeah, but they're Parisien....can't be pleased EVER!![]()
Back on the thread Topic.
Why is it that they don't recommend amplifiers to be connected to a power centre?
Hi John...in my case, i literally melted mine. I think the amp draw was too great and the power conditioner ended up choking and melting. This was my monster Gryphon Antileon...now my Colosseum goes straight into wall. Earlier, i had CJ mid-powered 60 watt amp...sounded better going thru the power center.
I just picked up a McIntosh MC122 power amp (80wpc - the baby "Mac"). I have a Monster HDP2400 power centre. What would you recommend in terms of connection?
i am no techie. I would ask Monster about the amount of current you can draw (including peak)...with an 80-watt McIntosh, i could imagine it might pull a lot of current during peaks.
Thanks Lloyd! I think I'll fire off an email to them. Can't hurt!
I agree, and disagree, with you there.
---- Jeeeez John, I got some excellent articles from Widescreen Review (the mag for which Amir writes articles sometimes), and Richard Hardesty, with few other guys, tested a tons of those things, and all the models from Monster power centres, and they faired quite poorly, except for their most expensive ones, which were decent enough but still behind the competition. In fact they were last.
These guys are experts, they open those power things (purifiers or regenerators) and they analyse their parts one by one, from the material used to how many of them, without forgetting what it does to the audio signals and the current needed from power amps.
That series (there are few mags testing several of them) is in my cavern (sous-basement), and I don't mind to do a search for you if you can't find reliable info or from Mc or from Monster.
Yours is the Stage 2 right?
-- Wow you're still there, and quite early too this morning.
It depends John, I'm sure you don't listen to music real loud at your place, and I bet you'd be just fine using it.
Congrats on your new Mc amp! :b
...And because your amp is stereo, and 80 Watts RMS per channel (rating), you should be good to go no problemo. It's more like for big multichannel amps that those things aren't good, unless you have one that cost several thousands of dollars and weights 100 pounds or more.
Hey, I can even ask Ivan's opinion on that over at AA.
Monster? No, I wouldn't trust them.
-- That's why I said you're good to go in your situation.
Ivan is Masterlu, the guy that you mentioned before with having the biggest signature you ever saw. He's the site creator, owner, and master of his domain. :b ...He's the McIntosh man.
. . . . What seems strange is the hospital grade receptacles seem to be installed upside-down. The earth pin is on top, whereas the earth pin is usually on the bottom. Having installed them both ways, it seems to sound better to me when the earth pin is up. . . . .
-- Quite interesting Gary.
As for the better sound that someone experienced, well, placebo effect perhaps?
