Amir, not sure what you mean.
Lloyd, I had issues with one of the 3 update files, so I haven't been able to listen. There's a thread on Computeraudiophile where others have updated and I'm sure they'll post their impressions.
I meant what the interface is. I have not looked to see if they support USB for example. But if they do, is it supported over that interface?Amir, not sure what you mean.
I think DSD over all inputs. Not 100% sure.
I agree Joe. One of the reasons I went with MSB was their long track record of providing upgrades for existing products. This helps ensure the "investment" isn't left behind as technology advances. Years ago I had a full Meridian setup, but got out because they didn't offer a viable upgrade path.
DSD is a standard input on ST/SC optical, MADI and SDIF-3. DSD can be carried over USB, but it's not a "standard".
Catastrofe - what other digital did you compare to? which mSB do you have? i am very focused on my next digital move, so would appreciate your advice.
MSB supports the DoP "standard": http://www.thewelltemperedcomputer.com/KB/DOP.htm
Will DSD be made available as file downloads that could be burned to DVD and played back on an MSB transport through their DAC ?
do you expect HDTracks to jump on board (DSD files) ?
