XACT S1. The music server you've been waiting for
JCAT WILL LAUNCH ITS OWN HIGH-END MUSIC SERVER AT AVS 2022 - XACT S1 – FEATURING WORLD’S 1ST 100% LINEAR POWERED MOTHERBOARD.
Designed from scratch, XACT S1, is a purist’s dream for those in the know. Based on JCAT’s ZeNA (Zero-Noise-Architecture) motherboard, the S1 does not rely on switching DC-DC converters. Instead, super-low-noise linear regulators are used exclusively making XACT S1 the world’s first music server running on linear power alone.
The market lacked a genuine audiophile-grade motherboard. Most of the available streaming products are assembled using general-purpose PC motherboards. According to Marcin Ostapowicz, JPLAY & JCAT Founder, such motherboards with noisy switching converters all over the place should not be used in a high-end audio system.
XACT S1’s proprietary motherboard, apart from linear regulation, features extremely low-jitter OCXO clock with ±5 ppb frequency stability. The extensive power supply section based on JCAT’s renowned OPTIMO linear PSU delivers 140 000 uF of capacitance provided by Nichicon’s flagship Muse and Fine Gold capacitors series.
Software is custom made and finetuned personally by JPLAY’s Founder, Marcin Ostapowicz, who promises superb sound quality and ease of use via included brand new JPLAY iOS app which combines Qobuz, Tidal and local content in a single beautiful interface.
According to Wojciech Pacu?a, chief editor of High Fidelity, the sound of XACT S1 is 'insanely difficult to distinguish from an analog source'. Come and hear it yourself.
When: 28-30th October
Where: Warsaw, Poland. Radisson Blu Sobieski Hotel, Room 718
The combination of KS/WASAPI Exclusive and Hibernate Mode produces an audible improvement in transparency, micro-detail, and soundstage depth, along with a lower noise floor compared to traditional players. Essentially, JPLAY eliminates unnecessary audio-engine stages and superfluous system processes, delivering a more precisely timed signal to the DAC. Already by 2010, JPLAY offered one of the most effective solutions for transforming an ordinary PC into a high-level digital audio source.
In subsequent years, the development of JPLAY never stopped. The introduction of the Dual PC Setup separated playback control from audio processing, further enhancing performance. Updates to ASIO support, expanded compatibility with a broader range of DACs, and optimization of buffers were introduced to minimize latency and maximize sound transparency. In 2013, JCAT (JPLAY Computer Audio Transport) was founded as a hardware division designed to complete the optimization philosophy of JPLAY, debuting with a high-performance USB cable, soon followed by the USB Card and other dedicated accessories. JPLAY evolved to support network streaming via UPnP/AV, becoming a more flexible solution suitable for modern hi-fi systems. This transition gradually culminated with the release of JPLAY for iOS, turning it into a true UPnP control point.
Today, with the launch of the JPLAY for iOS app, users can control UPnP streamers and DACs directly from their iPhones and iPads, optimized for managing high-resolution streaming from local servers and online services, and featuring an improved interface for precise and easy playback control.
As a regular and long-time user of ROON, I can confirm how excellent JPLAY for iOS has become. There is now no perceptible difference in usability compared to ROON. Apart from usability, the key aspect is the introduction of a dedicated, optimized streaming engine that reduces unnecessary network traffic, maximizing signal clarity. The app connects to UPnP music servers (NAS, PCs with UPnP software) and sends the signal to a compatible renderer, eliminating the need for a dedicated computer to manage playback. JPLAY has transitioned from Windows software to a comprehensive high-end audio playback platform with hardware solutions (JCAT) and an advanced mobile app.
Discussing JPLAY essentially means introducing JCAT's flagship product, their top-of-the-line music server: the XACT S1 EVO. It embodies years of digital audio development. The server is equipped with a motherboard powered exclusively by proprietary linear stages, aiming to reduce noise generated by traditional switching modes. Internal signal paths are wired with shielded Phantom conductors to contain high-frequency interference, and timing is managed by a low-phase-noise Master OCXO Clock designed to minimize jitter at its source. Completing the design, IMMOTUS™ mechanical isolation and a fanless design ensure operational silence and thermal stability.
Let’s go into more detail namely, how it was conceived during the design phase. Its immediacy and extreme sense of transparency are clearly a direct consequence of the design choices. The genesis of the XACT S1 EVO stems from the observation that almost all music streamers rely on mini-PC motherboards designed for general computing. In these more commercial designs, the CPU is powered by a multi-phase switching VRM, typically 8+2 or 12+2, switching at several hundred kHz and generating RF spurious noise. This often leads to the characteristic "coil whine," a type of noise that remains on the motherboard’s ground plane and can contaminate audio lines. All other sections chipset, USB ports, M.2 slots, RAM, and audio codec do not have their own multi-phase VRMs but rather small point-of-load regulators, individual buck or LDO regulators, also switching, which add further high-frequency noise. Even when using an external linear power supply, these onboard converters continue switching, so the noise remains trapped in the PCB, couples with clocks and digital buses, and ultimately increases jitter and background noise, giving the sound a timbre perceived as more “digital.”
Moreover, fully filtering out these spurious signals is very complex. In practice, the only truly effective route seems to be eliminating switching regulators at the root—a design decision that adds complexity but promises tangible listening benefits. From this premise, the ZeNA motherboard was born, followed by the XACT S1 EVO: a platform that replaces every DC-DC converter with ultra-low-noise linear regulators powered by an equally linear PSU, avoiding all internal switching, reducing noise, and minimizing jitter at the source.
Let’s rethink this carefully: one must envision a truly “full-linear” solution, radically different from the current market offerings, which increasingly rely on standardized hardware and ubiquitous switching architectures. Unfortunately, even in the professional realm, motherboards use components intended for generic applications—certainly not for audio playback—further aggravating the problem. The only viable path appears to be redesigning dedicated hardware from the ground up, conceived from the outset with a single goal: pure audio playback.
The XACT S1 EVO is equipped with a new type of fully linear motherboard. The ZeNA (Zero-Noise-Architecture) was conceived from the ground up to ensure the highest purity of the audio signal. This is not a recycled PCB taken from a mini-PC or general-purpose server, but a custom-designed circuit created specifically for audio file playback at the highest possible level. Unlike conventional platforms that rely on switching converters, ZeNA uses exclusively linear regulators (Low-Dropout, LDO) to generate all internal power supply voltages. Linear regulators operate by dissipating excess voltage as heat, thereby avoiding the switching noise typically generated by DC-DC converters. This design choice guarantees an extremely clean voltage supply for powering the CPU, chipset, clock, network controller, and every other critical component.
To reduce power consumption and simplify passive cooling—since the chassis is completely fanless—a quad-core 1.6 GHz processor was chosen, known for its efficiency in networking applications and low thermal output. In a full-linear design, the heat generated by the dissipation of linear regulators must be kept under control; for this reason, a more conservative processor avoids exacerbating the system's overall thermal balance while also generating no additional electrical noise.
The power supply section, which is always integrated inside the XACT S1 EVO, is the OPTIMO™ X1—a linear power supply based on a high-quality toroidal transformer, supported by a bank of smoothing capacitors with a total capacity of 140,000 µF, made using flagship Nichicon Muse capacitors (Muse and Fine Gold series). This enormous capacitance buffer further reduces voltage fluctuations and ensures a stable, noise-free current delivery.
Mains voltage is brought to the required level via linear regulators, without going through DC-DC converters. This approach is unique in the world of music servers, as it completely eliminates electromagnetic interference (EMI) and switching spikes that could degrade the audio signal.
In a digital system, one of the most crucial components for overall performance is the system clock and how it is powered. For the synchronization of digital data, the XACT S1 EVO uses an OCXO (Oven Controlled Crystal Oscillator) clock of the Stratum 3E type, developed in-house, with a stability of ±5 ppb (parts per billion). This level of stability, even in the presence of external factors such as temperature variations, vibrations, and electromagnetic disturbances, ensures extremely low jitter on the USB Audio 2.0 stream. Moreover, the OCXO clock is not powered by a switching converter, it too is powered via linear regulators, preserving the system-wide “all-linear” design philosophy.
Inside the XACT S1 EVO music server, only proprietary JCAT wiring is used specifically the PHANTOM™ Music Drive Cables, the brand’s flagship product. Each cable, entirely handmade in over seven hours, uses ultra-high purity copper conductors combined with precise impedance matching and laid out in a proprietary shielded geometry that suppresses both common-mode currents and electromagnetic interference. Derived from the established USB and LAN versions of the same series, these conductors drastically reduce noise and preserve digital signal integrity, an essential prerequisite to allow the system to fully express its sonic potential.
The final element is the IMMOTUS™ CL decoupling feet, made of ceramic-aluminum and also developed and built in-house. Each footer features an aerospace-grade aluminum body and high-hardness ceramic spheres arranged in a single-bearing system. Three units are mounted under the chassis of the S1 EVO. The mechanical geometry is optimized to channel chassis-generated vibrations into the most critical frequency bands, preventing them from turning into unwanted resonances.
Returning to the key issue, switching regulators, we can state that their widespread use in mainstream digital electronics does not serve the goal of absolute sound reproduction. A different point of view, a new way of designing computing components is essential to reach a new level of performance that would otherwise be nearly unattainable.
Let’s finally get to the heart of the matter: how does the XACT S1 EVO sound?
In a word: neutral. So neutral, in fact, that it almost seems… invisible. It may sound like a paradox: we invest time, energy, and resources to introduce a new component, and once it's in the chain, it “disappears.” But that’s precisely the appeal, we’re passionate about paradoxes, always searching for that extreme element capable of intervening as little as possible, allowing the music to flow freely, without filters. This means there is more, at every level. Its true virtue lies in its absence: every nuance, every whisper that was once seemingly or genuinely hindered or restrained now resurfaces with greater credibility to our senses.
As we ran through our usual selection of favorites, we couldn’t skip the album An Evening of New York Songs and Stories by Suzanne Vega (Qobuz 44.1 kHz, 24-bit). Once again, we’re inside the iconic New York venue, the Café Carlyle, where our ever-vibrant singer sounds even closer and more believable, performing with a naturalness we had never heard before. That edge, that brazen assertiveness disappears, giving way to a more refined territory where micro-details shine more brightly and emerge more easily, fully capturing the atmosphere that was felt in the venue, on that evening, in that moment. There’s more ambient character, more layering, and everything becomes easier to reconstruct. Less aggressiveness, which doesn’t mean less energy, but everything is more polished.
Let’s move on to another classic in our listening rotation: The Raven (Qobuz 96 kHz, 24-bit), which we recall was remastered in 2007 from the 1994 original at MasterSound Studios in Queens, New York. Here, Pidgeon expresses herself with greater resolution and clarity, channeling that physicality more toward expressive energy, bringing to the forefront those details that used to play a supporting role, now painting a richer and more multifaceted harmonic picture, naturally and without apparent effort. Once again, we’re faced with a more intimate, more immediate performance, but less harsh; the sound has been ennobled, it’s wearing a dark tuxedo for a special gala occasion.
It’s time to recount a meeting that speaks the deep language of four strings: the one between Christian McBride and Edgar Meyer. From mutual curiosity emerges a dialogue in which the two double basses become a single, grand voice. The result is But Who’s Gonna Play The Melody?, released on March 22, 2024, and available on Qobuz in Hi-Res 96 kHz/24-bit. It’s not a double album, but a “double” in the literal sense: two instruments, two visions, two eclectic and unique personalities in contrast. On one side is McBride (nine Grammys and a pedigree that spans jazz, R&B, and classical); on the other, Meyer (seven Grammys, an American double bassist and composer who loves blending classical, bluegrass, and jazz). The album was recorded live-in-studio at Ingram Hall at Vanderbilt University: a single room, a few ambient microphones, no overdubs. The choice of a chamber-like auditorium allows the interplay to be captured without filters, with the natural acoustics becoming a third musician—something very important to us.
On the first track, “Green Slime,” Meyer’s pizzicato ostinato is countered by McBride’s bow: a dialogue that surprises with density and spatiality like nothing heard before. Then the roles are swapped with juggler-like agility, and the momentum becomes so intense that it pushes the playback system almost to its limits. The bow, intensely vibrated, draws psychedelic swirls between the speakers, so refined I find myself staring at the new XACT S1 EVO music server. It’s what opens up this dimension: more substance but never a sibilance out of place, more timbral contour simply because there’s more micro-information, more vibrato as if from a freshly unsealed 180-gram record.
The second track, Barnyard Disturbance, is literally a “barnyard commotion” chickens fleeing or something of the sort. In four and a half minutes, the two bassists recreate the semi-serious energy of a rural courtyard, blending funk, bluegrass, and tightly hypnotic lines. Here, timing becomes the focus: the XACT S1 EVO is fast, but more importantly, it paces the music impeccably. It might sound like an exaggeration, but it’s really not: try powering your electronics with an undersized supply, and then you’ll hear the difference. Heard through a neutral and detailed server like the XACT S1 EVO, every finger tap or bow scrape stands out sharply, giving the illusion of being surrounded by that joyful, controlled... disturbance.
Bebop, of Course is McBride’s first composition and the third track on the album. The piece, McBride explains, “was built on the alternate blues changes of Confirmation: I just thought I’d do what I do best.” It’s a piece that alternates bow and pizzicato from the very first bar. All that plucking injects a constant vibrational energy into a sequence that seems endless, requiring speed so that the low notes don’t overwhelm and saturate the listening space. That’s not my case, not because of the room, which is acoustically treated, but especially because of the pairing of the XACT S1 EVO and the TOTALDAC Sublime, a pairing truly over the top. They set the rules, rules of precision, speed, and substance, without being thrown off by feedback waves.
Microdynamics emerge in micro-transients: light bow strokes, harmonics (those ultra-brief attacks that produce delicate high frequencies), and slaps, achieved by pulling the strings and letting them snap against the fingerboard for a sharp, percussive hit rich in high-frequency transients, bring most streamers to their knees, flattening everything. Here, the opposite is true: we’re almost in paradise, with a density and harmonic richness I’ve never heard before, everything is crisp, full, and expansive.
With the XACT S1 EVO, depth of field, seen as the difference between McBride (right channel) and Meyer (left), is crystal clear, yet the natural reverb of Ingram Hall remains intact, creating a stereo image that’s surprisingly airy and believable. And so, in just under three minutes, the duo manages to fuse the urgency of bebop with the breath of a chamber hall. The XACT S1 EVO music server, stripping away yet another layer of digital interpretation, places the listener squarely at the center of that dialogue and it’s here that you feel it all: perfectly articulated, chiseled, sculpted between the speakers in a privileged space no one can disturb.
The company’s entire know-how converges into an ambitious challenge: to create a reference-grade Music Server capable of handling digital streams with the utmost purity and temporal integrity, right up to the DAC input.
JCAT’s XACT S1 EVO stands out as both a radical and deeply thought-out proposal in the high-end music server landscape. The decision to eliminate all switching components both in the ZeNA motherboard and in the OPTIMO™ X1 power supply is not a marketing gimmick, but the conceptual and technical cornerstone of the entire project. Every detail, from the proprietary low-jitter OCXO clock to the Nichicon Muse capacitors and PHANTOM™ internal wiring, contributes to a result that can be perceived not only with the ears, but also in the sheer absence of noise.
The resulting sound is pure, stable, coherent free from that digital sheen that often taints even high-end solutions. What you get here is an absence, a cleanliness, a clarity that doesn’t attack the listener but restores music to its natural space and breathing room. And it’s not just about the hardware: the XACT OS™ operating system and JPLAY™ player are integral parts of this vision, designed so that every hardware element works in perfect harmony with the software, without bottlenecks or compromises.
In the world of digital audio playback where numerical “perfection” often conceals audible flaws the XACT S1 EVO proves that a linear approach, when implemented with extreme consistency and paired with software designed to match the hardware perfectly, can still make a difference. And not a subtle one. This is one of those rare creations where form follows function, and the result is not only technical but emotional, vibrant, and analog-like.
@Marcin_gps is it possible to upgrade the S1 with the better Clock?
From pictures I saw that the S1 ‘s motherboard can accept the pcb connector for the clock cable.
I've now had the S1 Evo and N1 duo for a few days, and my impression from the test drive is confirmed: the whole package is top-notch. When I was thinking of replacing my Innuos Zenith MK3 associated with the Phoenix USB, I was able to try out a highly reputed Dutch server at home (there are 2 possibilities, it's one of the 2...); the result was very good, superior to the Innuos, but if I remember correctly not as good as the S1 Evo+N1 combo, and for a much higher price. With the XACT duo, I find again what was said by reviewers, i.e. a lot of substance, naturalness, and above all the absence of frustration compared to my vinyl system, which wasn't the case until now. I should soon be able to test the Phantom USB, which I'll be comparing with the Laboga Ruby and the Hemingway Z Core USB. I've also tested the Linkup Cat8 S/FTP 22AWG Ethernet cable, which Marcin had recommended for longer lengths, and it's excellent, even compared with much more expensive “audiophile” cables. To be continued with the USB cable test
Reactions: Marcin_gps
I am the very recent and very happy owner of the full XACT digital solution, the XACT S1 EVO, XACT N1 switch, and XACT Phantom network and USB cables. I've used the S1 EVO for a while now and it makes the music sound so lifelike and so real. To me now streaming with the S1 EVO is just pure musical bliss. The S1 EVO blew away my prior streamer server, the Silent Angel Rhein Z1+ (albeit at a much higher price point). Because my experience with the S1 EVO was so positive, I decided to take the plunge and get the N1 switch and Phantom cables. As an aside, I hate it when I spend a big chunk of change on some audio gear, and then when it arrives I am scratching my head trying to determine if it even sounds any better. That was not an issue for me with the N1 switch and Phantom cables. The improvement I noticed when I put them in my system was immediately apparent and significant. I am absolutely thrilled with the sound I get with this XACT gear through my Lampizator Poseidon DAC. I encourage any WBF readers looking for a high end digital streaming solution to seriously consider XACT.
A few days after I received the N1 switch and Phantom cables I started a remodeling project requiring me to disassemble the audio system, and so my time listening with them so far is limited. Since my system is out of commission for 2 or 3 months, I loaned my XACT pieces to another audiophile friend of mine. He was so struck by the improvements he heard in his setup that he just told me he purchased a preowned XACT S1 on USAM. I have little doubt that he will end up with the N1 switch and the Phantom cables, and probably upgrade his S1 to the EVO as well. I'll post more when my system is back up and running, but for now I just wanted to share my initial experience with the full XACT digital streaming solution.
Hi,
Does anyone have an idea where to find troubleshooting guide of S1 Evo? Mine doesn’t want to start anymore (constantly flashing orange light…) after only a very few weeks where it showed random instability but would at least always reboot after crashing.
If I had such a problem I would ask Marcin first, seems logical.
Marcin helped me through the SD card reflashing procedure which took a little more than 30mn altogether. Easy step by step. Unfortunately it didn’t solve the issue and the unit has got to go back to Poland for some fixing. S*^%t happens and what matters most is the quality of the support I got from Marcin. We are left with a problem… and a solution! The phono line will be a reasonable backup until the unit returns fully fixed. Big thanks to Marcin for his help! Unit soon on its way back to the origins
Hi, as a frequent reader I have had not so much to contribute to this rich forum. I have recently purchased the XACT S1 and I'd like to share my experiences to contribute.
My system consists of an analogue side (Transrotor Fat Bob S with TMD and Konstant, Coincident phono Statement, Kuzma 4point 9 and Benz micro Gullwing) and a digital side. Into the FirstWatt SIT-3 into Coincident Pure Reference Extreme loudspeakers. Listening space is our livingroom, barely treated, but relatively good dimensions with listening position on one-third of the room.
My priorities in sound can be guessed already: First and foremost: Tone and timbre, secondly: transparency and intimacy in small scale music, third: then micro dynamic, macro dynamics and organization in sound, everything that leads to musical storytelling, then openness in grander music, only then placement, punch, deep sound, placement. I realize: everything very personal. I listen to mostly low to medium volume, sometimes medium-loud.
My references: I was a member of several amateur choirs, sang Bach quite a lot. My wife used to be a cello player (much much better then my singing) quite a while ago. A couple of classical and pop concerts every season. My record player.
The digital side consisted of a Lampizator Pacific Engine 11, Takacs, Philips, Telefunken ef802 etc. SOtM sms 200 ultra neo with either Farad super3 power or Pura the dodo power, a bit of fiber with the right unit in it and its converters. I once had very bad sound, turned out that the converter was powered by a good LPS in stead of the better Farad or Pura, that opened my eyes.. Muon filter, Jorma Ethernet cable, Ediscreation USB, LessLoss and Coincident Power cables.
I tried a European streamer in the price bracket a year ago and that didn't work in my system. Great customer support, and returned it without issues.
The XACT S1, streaming from Tidal was a very clear improvement over the pampered SOtM: Soundfloor clearly lower, darker background, more dynamic, cleaner sound, deeper better defined bass.
Then the XACT playing local Redbook WAV... Wow. Tone: my first testtrack is Cracking, by Suzanne Vega. For me the high guitar notes should be aimed at my bones, and later in the song the fundament should give me warmth and comfort in the pain. The sound was less warm than my Benz-Coincident 12ax7 combo but all the emotions where there, on a black rockstable canvas... Secondly for intimacy I use "Avalanche" by Leonard Cohen. (I realise this all makes me seem older than I am...). This song on vinyl is famous amongst my friends for literally flattening my friend who never listens past the first 40 seconds of a song before talking or asking for another song: he laid on his back on the floor and heard the whole song. I have yet to ask my friend, but my guess is that this is as close as I have heard from a digital setup. So checks for small dynamics, tone, intimacy and transparency. Then timbre: I listen to a recording of L'archibudelli Brahms sextets Andante ma Moderato. The combination of real humans playing technically difficult music, my accuton tweeters and non optimal acoustics (glass..) makes it sometimes a bit of a squeeze to listen to but is is an excellent testtrack for timbre and transparency: with the XACT my brain can make it so real that the tightness between the instruments is resolved in real wooden instruments being played by human beings, making room for all the melodies again.
Things that surpassed my vinyl (I am aware of the total cost difference, but this is the benchmark I have in my emotional connectedness to the music and my practical comparison, as the XACT is so much better than the SOtM and the former candidate, in my system and my priorities) in spades: Moussorgsky Pictures Reiner Bydlo: the openness in complex passages blew me away but what was even more impressive is how the story unfolded: I always use this testtrack including the playing children on the song before: suddenly I heard the joy, the jokes, the caprioles of the children, could see them getting dirty, them teasing their jonger brother and then from afar the big lumbering cart draws near, and pass, leaving me in awe, on the side of this road in the bushes amongst trees.
That is what the XACT does for me over and over: I discover stories, jokes, emotions, connections between lyrics and the music, against a pitch black backdrop. The sound for me is not forward (forward is not my preference) but it is festive and propulsive where it needs to be and peacefull and black where the music is. My music listening has changed somewhat: background listening can only be done with background music, not with other music with the volume low. Arvo Pärt is no longer Sunday lazy music but goes through the bone. Jack Johnson brings the sun.
Marcin is a great person to work with.
Qobuz to me brings quite a bit of the local WAV.
XACT S1 EVO music server at CAF — alongside Merason DAC2 and QLN Prestige 3 Gen 2 loudspeakers
photo credit: stereophile
Gregory Porter's "Take Me to the Alley" played with plenty of graphic detail, yet it was comfy, cozy, and warm. Fleshy physicality and a low noise floor were the system's most apparent virtues. Frank Sinatra's "Fly Me to the Moon" was airy, vibrant, and uplifting. Kenny Burrell's "Chitlins con Carne" featured his guitar in a giant, sweetly textured scrim; "Midnight Blue" was lightning fast and burnished. I wanted further engagement with this silky system, but duty—and more rooms—called.
Full report on Stereophile website:
https://www.stereophile.com/content...-gen-2-alma-music-audiowell-pleased-av-system
Reactions: Cinema e Sound
Sorry but I have a long standing slightly OT problem. It is NOT related to the S1 cause my previous server with other dac had the same annoying problem. The problem is that when I have a play list with 16 bit tracks and 24 bit tracks the switch from 16 to 24 bit tracks will be accompanied by burst of noise and the music stops. To get it going again I have to reboot the server. Again I have this consistently with the S1 and previous server with the build in Vinnie DAC a previous Meitner DAC. The only thing that’s still the same is my Etherregen.
Has anyone had a similar problem or is it a known problem?
Hi Ricky,
Which DAC are you using now? Do you have to restart the server or just a DAC?
Have you tried a different USB cable to your DAC?
Best regards,
Marcin
