After a few seconds the middle light turns off. The exact amount of time varies a bit with your Roon database size, with a small database 2-3 seconds.
Thank u Emile, this is exactly the kind of detail I was asking for..even more detail regarding database size vs. seconds would be great. Never occurred to me it was related to database size.
As u know, my database is 12.8 Tb and truthfully the press needed is all over the place.
Short press, long press still very confusing
A short (momentary) press and wait till the center light turns off is the correct way.
A short press signals the operating system (OS) to shut down the system safely. The time this takes varies depending on the system state (what Roon is doing mostly).
A long press forces the system to power off without allowing the OS to shut down properly. This should only be used if the OS has crashed and is unresponsive—a rare situation most users will never encounter.
This behavior isn’t unique to the Olympus; it applies to virtually all computers.
Reactions: Steve Williams
...thanks Emile. The Roon variable is the confusing bit for me, as it triggers me to wonder: did I press it long enough? Deep enough? Should I press again. So, it's helpful that it may be somewhat different from time to time...and patience is required. Admittedly, not my long-suit. Cheers.
If you press it your Roon remote should lose connection pretty quick, the system is then shutting down, the time this takes varies on how long it takes for the system to shutdown applications running, which is just the various Roon components.
The duration of the press should be less than 5 seconds, as 5 seconds or longer will bypass the OS and force a power off.
...OK, that 5-second value is very good info, Emile. Sorry if that is already in the manual and I am just not recalling it. But in any case, quantifying it is terrific. Thanks.
Reactions: Taiko Audio
as Emile would say RTFM:)
...yeah, I do, but there are areas that could use a little "bolstering" let's just call it.
Im yanking your chain as I am likely the biggest offender . In fact when Emile called me on on it somewhere in this thread I had to look up the meaning of RTFM :rolleyes:
Here's an attempt at making the Olympus I/O configuration as clear as possible using photos:
On the left side we have a Switch, then a BPS which powers the Olympus "I" module, this is then connected to our new PCIe interface card by means of a QFSP cable, this card is then plugged into the Extreme replacing the internal network card.
On the right side we have an Olympus "O" module containing the XDMI interface with an analogue output module fitted, this connects to another PCIE interface card by means of another QFSP cable, this card is plugged into the Extreme replacing the USB card:
Olympus "I" module, you can see the QFSP DAC cable being substantially "beefier" then the SFP DAC cable:
And the Olympus "O" module with XDMI interface:
The Interface cards:
What QSFP DAC cable is used here? It’s a specific brand and model or a generic one?
Two Olympus have arrived at Volent Audio, the official HK dealer of Taiko just now.
The powder-coating black may be the best Matt black colour finishing I have ever seen on audio components.
I know whose Olympus that is! ;)
Three anodized silver Olympus will arrive at Volent Audio within the next 2 weeks too.
Is one of them yours?
:p
The black powdered Olympus should be mine - Volent will deliver it to my home on Monday!
I must say Ben at Volent has the best customer service. He helped me reconfigure my rig and helped me with some (actual) heavy lifting. Really looking forward to getting back into audio with the Olympus (my system has been turned off for months now...)
Completely agree with you.
We are lucky to have Ben Lau/Volent Audio as the official dealer of Taiko in Hong Kong.
He is fabulous!
