Part 1 of @ray-dude's wonderful, in-depth review of the Olympus is now available online.
Traveling today, but looking forward to the discussion!
Thanks for the thorough report. I deleted the internal memory from my order after reading. Time to order a dedicated NAS.
Much to talk about here...
As I await my turn on The List, I appreciate getting your very thorough report on the Olympus. I laughed quite heartily when I read of your facility with heavier objects, thanks to your other hobby involving ~300 lbs. pinball machines. The friend that helps me with all of my heavy audio moves (and joins me for regular "stoner holidays" enjoying the system!) has all of the needed moving gear because his son buys old pinball machines, refurbishes them, and then sells them. A fun coincidence! Looking forward to Episode 2...
I like your style @jbrrp1 !
The hydraulic lift is a must, esp in the Taiko ecosystem
Another fantastic Reality Quest artical, RayDude!
On the Olympus ground posts, under what circumstances does Taiko advise it may be a good idea to use (or not use)?
I’m thinking to attach my ground box to the Olympus chassis ground (next to the usb ports) as I have every other component also chassis grounded to the box.
Or is there something in the Olympus tech that would advise otherwise?
I did some grounding experiments years ago; but my current set up doesn’t use any special grounding so I did not test.
I thought the recommendation from Taiko interesting because of the battery power newness of Olympus. Taiko team would be better to comment on the whys and when grounding makes sense, but the rules have definitely changed with the Taiko BPS
The little bit I have extrapolated is the direct correlation between the quality of the Power Cable and the ground. Perhaps by also grounding the chassis it creates a Negative effect?
As I shared with you Greg I have everything on a NAS now too. Synology DS224 +. @dminches recommended it. I have it right on the network rack and you don't even know its there. I wish I had a video of me setting it up! You would think I was dividing an atom! I think its pretty well known how incredibly inept/stupid I can be with this kind of stuff...
Volume up, John T!
Steve Z
Reactions: DW101 and John T
Volume up, John T!
Steve Z
Steve, I should have been listening to this while doing the setup! It would have been perfect as to what was happening in my brain at the time...
To help fill in the time....hope everyone well...enjoy the song:
And in other news, I received notification that my Olympus (#15 silver) cleared Customs in Seattle and is scheduled to be delivered tomorrow morning, 10/18. . .
Glad I did my workout this morning and that the lift-cart is ready!
Steve Z
Sorry if this question has been covered elsewhere, but which stacking option for the O and I/O units is preferable from a sound quality perspective (but keeping in mind potential structural damage concerns): a) O sitting on top of I/O; b) I/O sitting on top of O; or c) O and I/O sitting separately - not stacked? Thanks
Hi Cmarin,
The best option is obviously "c". Both devices on a dedicated shelf.
However, if you want to stack them, you should place the Olympus on top of the I/O.
The Olympus heats up and needs to dissipate that heat.
The real question would be :
Is there a significant advantage to having both devices on dedicated shelf???
From what I've gathered here and there, it seems not.
But I believe Emile (@Taiko Audio ) is in a better position to answer this question.
Cheers,
Thomas
Reactions: oldmustang
Ray-dude’s review was outstanding. Better than most professional audio reviewers indeed! Informative, a concise history and extremely well-written! Stereophile and TAS- hire this guy!
Hi Cmarin,
Cheers,
Thomas
Hi Thomas,
Thank you for your reply. Your suggestion that having each unit on a separate shelf would be best from a sonic perspective (even if it is not a significant effect) makes sense.
In my case, I’m very much looking forward to changing/comparing between the digital XDMI (AES) and análog XDMI.
Not having to move the heavy Olympus around and potentially risking damage to the units (or my older back!) while changing between the analog and digital outs would be another major advantage of having the units on separate shelves.
Look forward to hearing from others including the Taiko team as well - as long as it doesn’t delay the shipping schedule! ;)
Cheers
Reactions: SwissTom
Hi Thomas,
Cheers
Every shelf has some kind of influence so the answer would be it depends on the shelf ;)
If you want to experiment with different output options it would indeed be more practical to have the I/O on a separate shelf, for even faster switching for the quickest A/B scenario you could even place it upside down. It sounds great to me in all of these scenarios, the surfaces / footers we’ve tried so far change voicing / tonal balance more then they do absolute performance.
