Witch product?
Ola Swede
7
3
5
53
Hi all!
As you cam see on the pictures I have some acoustic products in my room…
It sounds great but the painting over the tv does not fit in my opinion.
Whitch product do you think would be the best alternative in that position , diffusion or absorption?
Ola
timztunz
157
104
150
Texas
Having never been in your room I can't say for sure. But it's been my experience that diffusion on the front wall has yielded the best results in my room. But it definitely looks like a "happy place". :)
Reactions: Ola Swede
Ola Swede
7
3
5
53
Thank you, it’s a very happy place ??.
Well, that’s the problem… Some say diffusiors, and some say absorption…
I’m thinking about Vicoustics Wavewood ultra lite or Vicpattern ultra wavewood so I get a little of both
morricab
9,531
5,069
1,228
Switzerland
Hi all!
Ola
Sacrifice of some live chickens is a witch product that often fixes a lot of problems…even acoustic ones…
timztunz
157
104
150
Texas
If that's the case you should also look at Stillpoints Aperture II Acoustic Panels. They magically do both, absorb and diffuse. Good luck!
BTW, @morricab was just making a joke because the title of your post is "Witch Product" rather than "Which Product".
Reactions: morricab
Ola Swede
7
3
5
53
Thanks for the input, I will take a look att that product .
Haha, now I get it
