What SET amplifiers have Realistic Midrange Magic AND have the Great BASS? Rock your Horns!
caesar
775
1,698
Which SET amps deliver on their usual virtues but also have great bass to rock out on AC/DC and Led Zeppelin?
Or does one actually need an SS amp in addition to a SET amp for their horns?
Sablon Audio
Industry Expert, VIP Donor
May 22, 2015
1,619
1,490
553
Caesar, I would recommend that you consider the combination of speakers / amp together rather than just the amp in isolation. Low frequency grip is not the natural preserve of SET amps, and therefore you will need speakers with a kind impedance curve as well as high efficiency. This approach could be ultimately cheaper than looking to high power SET amps which require huge traffos / chassis and may not have the traditional midrange magic of 300b / 2A3 / 45 designs.
abeidrov
VIP Donor
Dec 17, 2015
703
341
443
Moscow
Please, have a look at the Border Patrol amplifiers. They are famous for their excellent power supply units, which are apparently responsible for the unusual for a SET amplifier bass quality. Depending on your speakers, you can go for 8 watts per channel in single 300B output mode or for 18 watts per channel in parallel 300B mode. Pair them with good 300B valves like Takatsuki, and you will be surprised with what a 300B SET can do.
bonzo75
22,647
13,683
2,710
London
Ime, 845-based amps.
Shakti mentioned that if you get the KR Audio 211, you get the benefits of 845 mids with 211 dynamics
flez007
2,915
36
435
Mexico City
a hard call indeed, I have had Viva Solista and liked it a lot - my speakers have a low sensitivity rating so I moved on, but it was one of the best SET I have had by far.
16,219
13,682
2,665
I defer to my Europe-based, NAT Audio-loving, friends but I think one or more of the NAT Audio SET amplifiers would fit this bill.
(I continue to wonder about NAT Audio Magma New SEs on the Pendragon ribbon panels.)
etunes
64
25
925
Virginia Beach
My Air Tight ATM-211's driving Tannoy GRF90's play rock to insane levels without breaking a sweat.
christoph
4,689
4,075
825
Principality of Liechtenstein
I would like to add the also european based KR Audio with their Kronzilla Amps.
morricab
9,531
5,069
1,228
Switzerland
I guess the answer here is "It depends". If you have really sensitive speakers then rocking and midrange magic can come from quite modest amplifiers and usually for purity, simpler is better.
For rocking hard with SET, I have found that big bottles usually work best; 845, 211, GM70, 813, 805, T100, T1610 and 6C33C (i know it is not as BIG as the others but it sure sounds big) etc. These USUALLY do not have quite the midrange magic of 300B, 2A3, 45 etc. If your speakers are in the low 90db/watt range though you will usually find these smaller triodes gasping a bit and despite the delicacy of the sound they will not rock like the house like the big bottles. Parallel 300B can do a very good job but still doesn't seem to have the impact of a single big bottle.
Here is a list of ones that I have heard that sound very nice in the mids/highs and still rock pretty hard (again with speakers > 90db/watt and easy(ish) loads)
New Audio Frontiers 845SE stereo and monos
New Audio Frontiers Superme 300B (sweet but maybe a bit too soft to Rock hard with anything less than 95db/watt)
NAT SE1, SE2SE and SE3
NAT Transmitter
NAT Single (with 805 output tube)
KR Audio VA340
KR Audio VA350
KR Audio Kronzilla SXI
KR Audio Kronzilla DM monos
Wall Audio Opus M50 monos (great midrange and strong bass)
Ayon Crossfire III (was a bit dry with stock tubes but much more liquid now with NOS tubes Ayon rectifier and swapping 6N30 for 6N6)
Ayon Vulcan Evo
Vaic 52B monos and Vaic/Ayon 52B reference monos
Wavac HE805 (midrange to die for! Spooky good)
Lamm ML2 (that 6C33C does something special I tell you).
Aries Cerat Diana Integrated (dynamic monster with OTL like transparency)
Aries Cerat Concero 65 monos (as above but more of both)
For more delicacy I would think something like the Audio Note P4 balanced monos or Conquest Silver signature might fit the bill. I heard the orginal P4s drive the hell out of Magnepans.
Kondo Gaku Oh (also parallel 300B) or Kegon (parallel 300B) are sublime but maybe not "rockin'" enough.
Audio Aero Prestige monos (haven't heard first hand but a trusted source says they are unreal good sounding...hallucinogenic)
Kondo Ongaku and Gaku On (parallel 211)
Audio Note UK 211 based monos (I have heard Jinro but not in a non-Audio Note system so hard to decouple what I heard).
JJ-322. Nice delicacy and insight but doesn't rock very hard.
Audion Black Shadow: This amp seems promising but I haven't heard it.
Reactions: Amir
Lee Henley
178
120
350
England, UK
I play quite a bit of rock music especially Led Zeppelin, I use Audionote Empress Silver mono blocks which are around 6W SET, these play rock without any issues into Horn speakers
bonzo75
22,647
13,683
2,710
London
Lee is THE rocker, he has 100s of led zep bootlegs, autographed, ticket stubs and backstage passes autographed, and that day we were listening to the original vinyl and comparing it to some of the reissues. The originals had such better bass. Am sure there must be some reissues such are good, but the difference here was pretty high.
Reactions: chet atkins
spiritofmusic
14,626
5,435
1,278
E. England
He needs to hear LZ3 on Japanese vinyl
None of the U.K pressings I've heard come close
Otoh, Presence on Jap vinyl is more
shakti
1,444
2,411
480
Cologne, Germany
Depending on Speaker, I am using Air Tight 211 monos or NAT SE2 or SE3 .
All three can do a great bass punch on Rockmusic, if the speaker let them do!
Juergen
bonzo75
22,647
13,683
2,710
London
What about the original
spiritofmusic
14,626
5,435
1,278
E. England
I prob haven't heard bona fide originals
They're pretty hard to come by, and pricey, Jap vinyl often a v worthwhile alternative
"Immigrant Song" and "Tangerine" transformed on my copy from my 70s UK vinyl
Kcin
662
846
275
Canada
You may want to investigate Wyetech.
I have the Topaz with 211's and on the right speakers it does everything you ask for. It is primarily power supplies with film caps and multiple chokes. Very rigid supply and clocks in at about 125lbs
Lee Henley
178
120
350
England, UK
Audiocrack
2,187
695
1,158
NAT Transmitter
KR Audio VA340
KR Audio VA350
Ayon Vulcan Evo
You can add to this list Kondo Kagura amps: very, very strong 50 - 211 single ended - watts.
bonzo75
22,647
13,683
2,710
London
Which 211 tubes do you use? Shakti who uses Airtight 211 was particularly fond of the KR 211 tubes saying they gave him the best of 211 and 845 mix of power and mids
