Upgrading JBL 4429
Abolive
13
1
68
44
Jbl 4429​
Hello,
I would like to upgrade the internal wiring and driver connexions of my 4429, but accessing the HF and UHF drivers from the inside is difficult.
How would you do it? The sonoglass horns seem to be fastened from the inside and it a also looks tricky.
Thank you for your help
Abolive
13
1
68
44
All right, will do, thank you.
Still obliged if anyone as any hindsight here nonewithstanding :)
Abolive
13
1
68
44
I will make an external crossover with improved parts as well, I just want to do everything at once.
Robh3606
1,485
474
1,155
Destiny
Be very careful if you decide to crack the cabinets. See if the UHF drivers have slip on clips. They can be the ones that lock onto the driver terminals. You have to carefully engage the locking clip before you try to remove the wires. If you don't I have seen more than one damaged driver with a clip broken off.
I would not change the wiring out. It's not worth the risk of any collateral damage.
Rob :)
Abolive
13
1
68
44
I'm not sure it is the best part of the forum to ask my questions, I've opened another thread here :
I'll focus on the crossover upgrades there. Thanks
