I currently use 2 x PS audio P5 an a dedicated 15A circuit each for all my components (except for active woofer cabinets which are on a shunyata hydra 2 each, on a separate circuit).
I am intruiged by the stellar reports about Shunyata Triton and interested in trying one as a replacement or complement of the P5s. However, the number of permutations of what I can do with one Triton are many.
I can plug both of my poweramps into a single Triton on a single circuit (should be just about enough power for both) and leave my front end components plugged into a single P5. Alternatively, I can use the triton for my front end (MSB Dac and ARC ref 5SE) and share a P5 between the two poweramps. Ideally, I should get also get another circuit installed and use one circuit for each poweramp (and possibly one active woofer amp), and one circuit for front end components. After I have done a "triton proof of concept", I might just do that.
My first question is this. Can I expect more improvement moving my front end to Triton, and running poweramps over P5(s), or vice versa?
