Spectral and Nordost
alessandro61
1
Hi folks!
My name is Alessandro and I'm writing from Italy, Milan.
First of all I would like to tell you that I am very happy to share with you my passion for High End and, in my way, for Spectral Audio products.
I'm playing music with Dma 260 s2, Dmc 30 ss s2, Magico Mini 1st version, Dcs Puccini combo, MIT interconnect cables, and I wonder if someone uses Nordost power cables instead of MIT with Spectral gear.
What about your impressions?
Thank you for replay
ack
May 6, 2010
6,774
1,198
580
Boston, MA
Welcome Alessandro! I can only share with you that I have not had as good results with MIT power cords as I have with Shunyata in sheer bass weight and dynamic range - measurable, too, with test tones; no experience with Nordost per se. Signal cables are all MIT.
Mobiusman
705
564
1,655
Jersey Shore- waterside
Welcome Alessandro,
I too have a DMA 260, but use a tube BAT preamp. The combination of the two is wonderful to my taste. When I first bought the Spectral, I was using Shunyata Anaconda interconnects, which sounded wonderful when I had a Bryston 4BSST2, but just sounded wrong with the Spectral. I reluctantly purchased, at great expense, MIT MA-X interconnects and digital cable, plus Oracle MH-80 speaker wire. After I got out of the financial ICU, I must say that my sound improved markedly and my amp seemed to be more stable and powerful. Since those changes, I have had no problems and actually have the best sound I have ever had.
I do want to say that I am a true Shunyata believer and have their PC's, receptacles, Triton and Typhon in my system. Unfortunately, the interconnects that they were making 18 months ago just did not work with the Spectral. Having just spent a day at Shunyata on Friday, I do know that their new interconnects have changed considerably and may now work.
nirodha
694
308
1,625
Hi folks!
I have tried almost all MIT power cables (AC1, 2 and 3) and they are not the best. Using top line MIT MAX for the rest (amps: Spectral 360) / Spectral 3000 feeding dCS Elgar Plus). If you are in for a top power cable, put Elrod on the top of your audition list. Have fun!
CGabriel
618
92
265
WA, USA
www.shunyata.com
Welcome Alessandro,
Spectral equipment requires the use of the MIT manufactured cable. The Spectral has an exceptionally wide frequency bandwidth and has chosen to incorporate a high frequency filter in the cable to prevent oscillation. If you don't use the specified cable it will void the warranty.
If you use Spectral equipment you should use the cable that it was designed to work with.
nirodha
694
308
1,625
True. But this does NOT apply to power cables.
kennyb123
858
806
1,155
Kirkland, WA
I power all my electronics with Nordost Brahma power cords. This includes my Spectral DMC-30S preamp and DMA-150mk2 amp. These responded incredibly well to the Nordost cords. I could not be happier with the results. I can't say how this would compare to MIT's own power cords. I've never tried them.
