Preamps... nothing is perfect.
4,704
Here is a nice chart,note the vast difference in voltage drop(the lower the better)
Why should lower be better? IMHO we should use the the rectifier that introduces the voltage drop intended by the designer. Changing it will operate the stage at voltage and currents that will differ from what was meant originally.
christoph
4,689
4,077
825
Principality of Liechtenstein
Hi Stavros. Flyer came over to my place this afternoon with his Incito S. As I had several rectifiers at hand (Philips 5R4GYS and KR 5UAG Lampizator Anniversary), we tested them and we quickly concluded that the Sylvana you selected was the best.
Kind regards,
dcc
Thanks for the info regarding your recti rolling.
How did you like the Incito S?
What preamp did you compare it to?
I love my regular Incito but I guess the Incito S is quite a step up in sound quality.
christoph
4,689
4,077
825
Aries Cerat
360
609
333
When choosing for a new design,lower is usually better as it means lower internal resistance. Of course changing rectifier type ,in existing design from user side is not only not optimal ,but many times dangerous.
Ex.if you replace a rectifier with 50v drop with one with 10v drop,not only you change operating point but some equipment with marginal voltage rating in capacitors may not like it too much.the opposite also applies.replacing a rectifier in a design using 5ar4 with a 5r4 for example sets the OP way off.
Reactions: microstrip
dcc
662
1,303
1,230
Continental Europe -
It was not a comparison as such. I already heard the Incito S in another system and I have heard Flyer's Impera many times at his place. Flyer is very close audio buddy and we were both interested to listen to the Incito S in my system and to do some tube rolling.
We opted for my Tenor Audio Hybrid power amp instead of the big Krell mono amps. We only listened to vinyl through the Allnic phono stage. So it was somehow a full tube setup.
Unfortunately, the Incito S was missing true balanced inputs, so we coud not connect the big Studer tape deck.
I really enjoyed the Incito S. It is transparent with a great sense of pace and rhythm.
Reactions: christoph
christoph
4,689
4,077
825
Thanks
How would you compare the Incito S to the Impera?
bazelio
2,494
1,748
345
California
@bazelio. Are you able to set the bias on the tubes in any way?with these specific tubes can change dramatically with a minor operating point shift.both tubes are top notch as almost all in this family
I'm just following the recommendations from the designer here. He shipped it with the Russian 6J11, Siemens E280F, D3a and said I could swap to find the sound I liked. I really did not like the 6J11, but fell in love with the unit after first hearing the E280F in it. Then recently I changed my passive line stage and now I'm enjoying the D3a.
christoph
4,689
4,077
825
I would definitely opt for the Impera. The Inceto S is a great preamp but the Impera is even better.
I bought my Incito from my friend Michael who bought an Impera :cool:
I wonder if the Incito can be upgraded to the Incito S, but I have a sneaky feeling that it is not possible :oops:
fish fingers
25
How about the nutube B1 First Watt? The only issue is it's a kit. Pretty sure the full kit inc chassis is now available to order
bazelio
2,494
1,748
345
California
Pete Millet designed a headphone amp around the Korg Nutube a couple years back. I demoed it for a week or so. Interesting and all, but sound-wise it was all midrange all the time. Also, those Nutubes were hyper-microphonic. A slight fingernail tap on the chassis would be amplified.
