I'd use it because it shows the complete musical envelope comprised of a complex mix of frequencies as opposed to a sweep. I use sweeps for overall FR response pretty much to look for gross anomalies in the speaker/room interface.
Recordings like this could be helpful in checking out what part of the envelope is being emphasized for a particular speaker set up configuration. Like exaggerated decay for example that could be a product of a room with too long a reverberation time. Going up and down the scale could show you what frequencies need damping. So such a disc would also help the user appreciate ratios between direct sound and reflected sound as he or she played with different on and off axis relationships as it pertains to the phantom image. There are other uses but I'm a bit short on time because I'm going out with some buddies.
As for the genesis of this, sorry I couldn't resist!
Gary and I had been having an exchange about following scales when setting up speaker positions to be able to get reasonably consistent image focus and pitch articulation from top to bottom, or in the case of our discussion from the bottom up. The discussion stemmed from a short piece I wrote for
newcomers to the hobby, who don't have access to measuring equipment and most probably wouldn't know how to use them or interpret the results even if they did have access via freeware or whatever. I also don't see why more experienced hobbyists can't find some use for it. I don't think Gary ever meant for it to be anything more than a tool and not as a definitive example of what a piano should sound like.
What Bruce pointed out was not an objection to the process but rather to short comings in the recording itself as well as some issues regarding consistency of pressure on the keys which could be easily programmed on MIDI. I didn't see Bruce invalidate or attempt to invalidate the use Gary and Steve have for the recording only that a better set of recordings would be, well......better.
Send me a copy Gary. I'll replace it when someone gets the Bosendorfer folks to program and record one of their own.
