Noise Stopper Plugs - Do you use them?
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
My Marantz PM-KI-Pearl came with a full set of these plugs for use on any open/unused IC connections. I have not done a comparison yet to see if they make an actual audible difference, but from what I've read they are supposed to help lower the noise floor a bit. They are installed.
Are these plugs of more benefit to entry-level high-end gear or does it also make a difference with SOTA equipment?
I'd love to hear your thoughts on this.
DaveC
3,899
2,143
495
It depends on how the switching is done... ideally both the signal and ground inputs are switched but often the grounds are not, in this case the shorting caps can be an advantage.
thedudeabides
2,184
694
1,200
Alto, NM
Johnny,
Totally worthwhile and audible from my experience. Haven't tried on more modest systems.
I have the Cardas caps without shorting plugs.
DonH50
Jun 22, 2010
3,968
326
1,670
Monument, CO
I have used various shorting caps in the past but do not now. The only time I ever heard or measured a difference was in very poorly-designed equipment* in a high-RF field. Isolation among inputs is usually high to begin with and these would only reduce the impact of input noise coupling (which is normally far, far below a normal signal input). IME noise entry is far greater via other coupling routes than via unconnected inputs.
I have had a few components (preamps especially) that exhibited crosstalk high enough to hear faintly if the unused source was not turned off. Again, this was typically with the volume all the way up to hear a faint signal from another input, not anywhere near normal operation.
YMMV - Don
p.s. One example of a poor design was a phono stage that tended to ring and oscillate in the presence of high EMI/RFI if not terminated.
