I'm guessing you can't go too wrong with either of these turntables.
+1
I think people are drinking too much kool-aid if they think the Kronos is superior to the AF1. In terms of quiet, no way a non air bearing design can beat an air bearing in the low rolling noise dept....I will also add that no air bearing is quieter than the AF1 since it doesn't even have a bearing. The entire platter floats on a cushion of air. The spindle is not a bearing..only a centering device for the floating platter. In any event, the review is careless. Even though the guy owns AF1 and CA Statement...he was probably greased with a free Kronos for his glowing and non tech specific review. Happy spinning folks !
... Even though the guy owns AF1 and CA Statement...he was probably greased with a free Kronos for his glowing and non tech specific review. ...
I know the reviewer & the system very well. Is Kronos Pro , quiet ? Yes . Is it quieter than AFO ? To his ears yes. To my ears ???
He bought the Kronos Pro at a good price . Anyway this review is merely his opinion. Just treat it as informative & not necessary conclusive . After all it's different tonearms & different cartridges for all 3 TT. To me , at least it is better than the ridiculous video review who based his conclusion on listening to 3 different syst at 3 different place & come to the conclusion that it's the most dynamic TT in the world - that is certainly a bought review . Again is an opinion only
It's $35000 for the Kronos Pro, and $8500 for the Black Beauty tonearm.
How big is the difference between Sparta and this? Asiufy, we both like Kronos, Avantgarde, Koetsu...you really should swap your dac to Lampi
Here's the price.
The Kronos Pro is a limited edition run of 250 units. There is no "standard" Kronos, or maybe you can consider the Sparta to be that.
I guess I need to hear it for myself. As Frank750 mentioned...he owned the SME before the AF2 and he says the AF2 is quieter to his ear. So much for un-audited measurements. And if I seem defensive, I am not. In terms of listening preferences...everyone hears differently. Sounds like the Kronos is a sonic bargain.
Perhaps you should audition a Kronos and give us a full report?
I own both. Bought both of them used and set them up myself. The Kronos with a SME V12 and the AFO with the Graham Elite. Both arms are with the Clearaudio GF, the one on the AFO not yet broken in, so a real comparison is not possible.
All the same, I find it impossible to say which combination is " better ", because I like the sound of both. More of that later though. I heartlily dislike the use of words like better here, because what is the reference? Better according to what? I think, when we use that word or similar, some point of reference should be given.
That said, l find that in my rig, compared to the sound of the AFO, the Kronos sounds richer, more full bodied, more fleshed out. Often I find myself turning down the volume, when listening to the same piece, which was on the Techdas before, because the rendering of the Kronos seemed louder. As I had noted, the cart here is fully broken in. Stability of the Kronos is first class. Long drawn out notes or decays on violin or piano are absolutely stable.
(I am cursed with absolute pitch )
Same with the Techdas of course. The absence of spurious noise is uncanny. Tics and pops are somehow moved unto another plane, something the Kronos cannot do as well.
Listening to the AFO with material I know well, I find that the entire information is there, nothing missing to my ears, before a background of a silence, which lets me think of good digital. Sometimes I find the sound a tad dry, but then this cart has only few hours on its back. When I take the same LP over to the Kronos Ltd, I get the same information, no new mikrodetail added, I find, but the whole presentation as if painted with a bigger brush. The soudstage moves forward, but with the same fairly good definition as with the Techdas before.
From what I have described, one would expect, that the Kronos gives more bloom on instruments. Not so, here I find the AFO a little closer to when I listen to a real violin for example, perhaps because of this incredible silent background, which the Kronos cannot match.
I like both setups, find none " better ", simply very different.
With the one Music is beautifully rendered in say a hall with good reverb and you sit close to the music, with the other, you are placed a few rows more back snd the hall seems a tad dry. Wonder what the Techdas combo will sound like, when the cart is fully broken in.
why? how does it compare with MSB higher end offerings?
