Nat Audio - giant killers?
4,702
Custom indirect speaker protection circuit ?
Crowbar arrangement with thyristor that melts a fuse that is switched into the amp power cord, by vaporising the fuse the amp is off and no damage should occur. The detection of souch a failure can be done by placing a hall effect sensor on the input of the ribbons.
Just an idea...
Most of the time the energy stored in the capacitors of the amplifier is enough to destroy the panel. Quad ESL63 electrostatics had a crowbar arrangement with a thyristor that sometimes fused the output transistors of the offending amplifier ... :)
spiritofmusic
14,626
5,435
1,278
E. England
This forum always seems divided by those who think all audio/setup/synergy/room conundrums have a simple solution, and if that solution doesn’t work, try another.
And those who chime in with words of wisdom. Thanks Micro.
The way forward here would be home trial of said Graz Duettas, with a SS amp like Parasound to a/b v my NATs.
16,219
13,682
2,665
The old Nat distributor from Holland, who put NAT on the map drove his infinity (not the Genesis but the 201 or 202 or so) with NAT magma. I did not like it, thought it was slow and under driven. That was three years ago though, had forgotten about it.
That is very interesting! Are you sure it was not a Genesis 200? (Infinity made the Betas but I not recall Infinity making a Genesis 200 type of system.)
What amps would you today want to try on that speaker system?
GMKF
432
86
135
Munich
But we dont wan't glass parts of a fused tube sticking somewhere insinde Rons body do we?
Via NAT's website "high capacitance in power supply resulting to over 500joules of energy storage"
Thats enough to fry a ribbon :p
spiritofmusic
14,626
5,435
1,278
E. England
Well I tripped on my carpet, landed thigh down on my Nat SET and ended up needing minor surgery to remove multiple shards of 211 tube from my leg.
No ****!
So if Ron falls foul of this, I can say I was there first.
Zero000
2,988
1,141
478
No ****!
When did that happen?
spiritofmusic
14,626
5,435
1,278
E. England
Two months before I started packing for my move, Jan 2016.
Peter was en route from Somerset to London with a Magnetostat for demo.
I woke up to go over and put my tube amps on, made a call, went over to adjust the volume, and <WHOOPS!> took a little dive into
my amp.
Demo aborted, but Peter charitably took pity on me, and carted the amp off to fix it.
morricab
9,531
5,069
1,228
Switzerland
Only if you are measuring the speaker sensitivity in anechoic conditions. However planar manufacturers mostly lists an "equivalent" specification of sensitivity, that is taken at the a "typical" listening distance in a "typical" room. Remember that most planar manufacturers do not own or use large anechoic chambers.
True story: When measured SPL of my Acoustats the level was only down 1db compared to the immediate ftint of the speaker. That was one channel driven. In a real room there is very little drop off with distance for a large planar linesource.
You can take the one meter SPL to hold steady out to 3-4 meters I have found (my listening position was 3.5 meters). Big Kronzillas drove them beautifully and even the VA350 did a cracking job.
spiritofmusic
14,626
5,435
1,278
E. England
I listen at 4.5m distance.
Duettas would be 3m to front wall.
morricab
9,531
5,069
1,228
Switzerland
You are right Ron, Genesis made the 200. Infinity made Betas (I owned a set), Gammas, Deltas, Sigmas, Epsilons and Omegas as well as the mighty IRS V and the 4 box RS I, IIB, 4.5 etc.
bonzo75
22,647
13,683
2,710
London
He sorry, confused... Yes, genesis 201 or so
awsmone
1,616
514
435
Canberra Australia
Yes it’s interesting how panels load a room differently to cones
Cones tend to drop off at the square of the distance
Panels in a linear relationship
I placed my CLX in the same position as the morel, which required lamm M2.2 to fill the room, and still clipped
The panels are much louder
Bass fills room much more evenly
Mine is a largish room 6 m by 13m, with 2.3 m ceilings
Panels are 3 metres from front wall
I listen 11 ft from panels
But yesterday I was standing at the rear of the room, and if anything I think the sound might have been better
I was listening to the gun battle from Billy the Kid
To describe the bass thwacks as jaw dropping and fast was an understatement
The Goldmund’s are amazing with the CLX! , I have never got them to clip, even when playing ear popping loud..
awsmone
1,616
514
435
Canberra Australia
Have heard both 1 and 200 series Genesis
Argonaut
2,423
1,655
530
N/A
Have you ever measured the base response of your CLX's in your room awsmone? True....that with great amplification the quality of the base produced by the CLX's can be absolutely Stellar.
ihmeyers
262
193
325
Palm Beach County, Florida
Does anyone know of an upgrade to the DB-25 cable the NAT Magnetic uses between the preamp and the power supply? Would any DB-25 work or would it have to be a specially configured cable?
Thanks! :)
Verastarr
180
64
160
Thanks! :)
should have a magnetic soon, and if the cable can be upgraded, I am the guy to do it. will let you know.. What have you compared your Magnetic to ? Kind of stuck on whether to go Magnetic or Magnetostat ..
Cheers
Reactions: bonzo75
spiritofmusic
14,626
5,435
1,278
E. England
Can you keep me posted on any high quality DB-25? I run one btwn Nat Utopia pre and it's psu.
ihmeyers
262
193
325
I purchased a Tubulus Argentus DB-25 Cable V2 from highendcableshop.com in April of this year. I think it was about $700. It works very well with the Magnetic.
spiritofmusic
14,626
5,435
1,278
E. England
Hiya, v interesting. My DB-25 is a pair of cables, male to female. Is this how the Tubulus is configured?
