CORRECTION: Hi Roger,
I realized there is an 'in between' setting of 18db rolloff, and we have settled on this. Essentially, the snap of the bass is more delineated at 24db slope, and with 12db obviously you hear less of the snap as more signal comes in underneath it which causes you to listen to a bigger bass signal with more than just snap. My observation is that perhaps because the sub-15hz part of the signal is possibly not as flat as i would like, while lowering the slope allowed the system deep bass to seem more 'full/rounded/natural'...it also seemed a little 'wooly' for my taste.
However, upon listening to 12db rolloff vs 24db rolloff, it was also clear that beneath the snap, the steep rolloff may have been artificially truncating the signal. Once we went to 18db slope, that natural rolloff/rounded element filled in again below the snap (which we can also again hear and enjoy with excellent delineation), but without the teeny bit of extra/uncontrolled rumble which detracted from the snap. And it feels more natural/fuller.
Very subtle and given how these rolloffs work, i would imagine my observations are not at exactly the 15hz signal but 'around that entire range' both plus and minus. In any event, i have now put away all the controls/manuals, etc and will live with it for a while and see.
I also have set the movie setting for the Velodyne at 18db rolloff below 15hz (when i watched Star Trek, i noticed that when the Enterprise warps, the deep rumble was not quite as deep, impressive and propulsive as i had recalled from our other room)...so I will see what happens next time we watch a few action flicks, particularly Star Trek.
Will update if anything changes or if i find i continue to learn more about what this setting change has done to other tracks. Hope that is helpful.
Lloyd, I came across this thread after doing a search....
Quote:
I currently own a Velodyne HGS-18, but am concerned that I am not CERTAIN as to what my settings on the sub should be to get the maximum impact from it for my system. My mains are big Polk SDA-2.3's, my centers (front and rear) Polk CS350's, and my surrounds Polk Fx-500i. I'm running a Yamaha RX-V1 with the all of the speakers set to "Large", and with the subwoofer set to "Both", meaning (I believe) that the Low Frequency Effects are sent to both the mains (which can go pretty low) and the HGS-18. My thinking behind doing this is that the Polks can go low enough that I should have the HGS-18 just emphasizing the very bottom end (40Hz and below)--and I THINK that if I set up the Yamaha so that the LFE channel goes exclusively to the HGS-18, I'll lose out on anything from 90Hz to 40Hz with my current settings (my current settings are: High Pass Crossover: 80Hz; Low Pass Crossover: 40Hz; Subsonic Filter: 15Hz; Log Volume Level: about halfway, with electronic volume control to adjust for different sources.) Anyway, I'm not exactly sure that I am setting this up optimally, and I would LOVE to hear your opinion and advice as to how best to set this up. Also, because I'm not in the know, could you explain to me like I'm a three-year-old what the High Pass Crossover, Low Pass Crossover, and Subsonic Filter selections are meant to control and how they interact? (I have a vague understanding, but not enough to feel confident that I am setting this thing up properly...)
Hi Chad,
Let's start with the crossovers. Since we're bass kind of guys, we'll start at the bottom with the subsonic filter. Basically, this is the point at which the sub will begin to roll off the lowest frequencies it plays. So, if you have it set to 15 Hz, the electronics will, starting at 15 Hz and heading downward in frequency, play those frequencies gradually softer (how gradually depends on the slope of the crossover). So, 14 Hz will play a little software then 15Hz, 13 softer than 14, and so on. Depending on your musical/theatrical tastes, you may want to raise this a bit since having the sub not play the deepest frequencies frees up amp headroom to play higher frequencies louder, and sometimes there is noise down at those frequencies that is unwanted. Of course, for the HGS-18 we set it at a default of 20 since we think that's the best setting for most applications, and your HGS-18 has little trouble playing those frequencies accurately.
The low pass crossover pertains to how high the sub plays. This defaults to 80 Hz, and the rolloff goes upwards. So, 81 Hz will play a little softer than 80 Hz, and so on depending on the slope of the crossover. You want the sub pretty much silent by 120 Hz, since that is the frequency at which the bass can become directional and expose the location of your sub. You have it set relatively low at 40 Hz, so the woofer is in fact doing little at, say, 60 Hz and above.
The high pass crossover pertains to your main speakers. This dictates how low the mains will play. A high pass crossover set at 80 causes the main speakers to play a little softer at 79 Hz and so on, again depending on the slope.
All the crossovers are very important since they dictate the relationship between the sub and the main speakers.
Now let's talk about your Polks. Whatever anyone tells you about this is their opinion, and you need to experiment to get your system sounding good to you.
First of all, even though your Polks are pretty "big," I would still set the setting on the Yamaha to "small", and I would change the setting that is currently on"both" to "sub only" or however it's labeled. This is because the HGS-18 will play the mid-bass frequencies louder and cleaner than your Polks, since it has lots of power (1250 watts dedicated to the bass), and a servo to keep things clean and tight. I would then run the low pass crossover on the HGS-18 up to 80 or so and adjust for taste.
You can try variations on this, but I would definitely give the sub more to do in the 40 - 80 Hz range. I believe that your whole system will benefit.
Hope this helps,
Bruce
Bruce Hall
Velodyne Acoustics
http://www.avsforum.com/forum/113-s...304306-offical-velodyne-support-thread-2.html
I have my settings at the lowest variables. On mine it seems the volume effects the bass quality the most. Right now it is pretty much seamless and because I have a L & R sub setup with the big sub crossed at 40hz and the Vel at 80,the Vel volume needs to be spot on or it becomes unbalanced. I need to study this and then experiment a little. I'll post later....thanks Lloyd. P.S. the bass is really articulate as the Virgil Fox recording has a bass signature that I have never heard before...real definition.
And I'll just add that when I put my electronic crossover in my ground loop,it reset the entire system. This is not uncommon in my experience but why with the crossover is kind of strange. When I say "reset" I mean that the soundstage collapsed totally. I happened to being playing the soundtrack from Lawrence of Arabia and the big drums went from a 'normal" reproduction to a hardly audible,but they were still there. I sat there for about 3 hours playing this same recording and listened as the soundstage begin to open up. I would guess it took about 10 hours or more.The result was a much more delineated bass and much larger in image. I've got a lot of things going on sometimes,but now I think the system is stabilised. I find this grounding fascinating.
