MIT vs. Nordost IC's
dentlfly
10
1
106
charlotte, north carolina
i have been auditioning many brands of IC's to replace my tributaries. anyone have experience with the MIT SL-Matrix 50 and 50.2 series and the Nordost Tyr2? i have auditioned many brands and these are the last 2 to audition. winners so far are cardas clear, WWplatinum eclipse 7 and kimber 1036 series. thanks.
ed
dan31
1,020
369
1,653
SF Bay
I have not heard good reports for the MIT matrix SL series. The MIT matrix (non sl) gets very positive reports. Lots of info on MIT cables in the Spectral forum.
ack
May 6, 2010
6,774
1,198
580
Boston, MA
Not a fan of the SL line either, although positive-feedback had a glowing review of the 50/90 combo. It's also true I had a Tyr2 which I couldn't get rid of fast enough, once I tried the Oracle MIT
marty
4,209
2,520
United States
If you could share what you liked about each of your "winners" thus far, that would be helpful. I am also not a fan of MITs below the Oracle series, but then again that carries a hefty price tag and you may not need it. The Cardas Clear is the only other cable in my system besides MIT Oracles and its pretty hard to fault (and a relative bargain to boot). There's probably a good reason it is the reference cable of Audio Research, but what's right for them may not be right for you. The only real answer is what you think sounds best in your system.
dentlfly
10
1
106
the cardas clear is just so easy to listen to; lots of low end, nice soundstage, no brightness and detailed(but others more detail and air). nice construction as well, great XLR connectors. kimber select 1036(RCA) very articulate low end, big soundstage and lots of detail. a slight bit of edginess on certain notes in the upper end. vocals and instruments about half way up center stage. WW platinum eclipse 7 similar to kimber. huge soundstage and detail. also some edginess to some upper end. vocals sounded very smooth. MIT's coming today to audition but they are the sl-matrix 50. there is also a pair of oracle 50.2 that i could audition but they are pricier cables. auditioned nordost a month ago; local dealer bringing back over tomorrow but what i remember of the Tyr2 nordost was the really wide soundstage and detail and air around instruments and vocals but not as articulate in the low end. and the center stage went way up and slightly more forward. thanks. hope to get some more feedback from members that have used or tried these cables. these are all IC's. starting there first and then will try different speaker cables. consensus seems to be power first , then IC's, then speaker. already did power.
ed
thedudeabides
2,181
691
1,200
Alto, NM
Shunyata Research?
Good luck on your search. Kinda like choosing your favorite ice cream.
I assume you are aware of Fatwyre / The Cable Company. Probably have the largest selection of wire on the planet and you can audition to your hearts content.
es347
35
1,620
Midwest fly over state..
thedudeabides
2,181
691
1,200
Alto, NM
With all due respect, I don't think cable reviews are very valid since they are so system dependent and subject to one's personal biases.
audio.bill
550
84
340
Chicago suburbs
Without any disrespect to you, isn't that really true of all audio gear? This is a very subjective hobby by its nature and each component interacts with all others in a system to create the resultant sound quality. I believe that no component stands on its own, but reviews can still be of value to give you some idea of of a component's sound. Of course everything's still relative.
4,702
If you know about the reviewer preferences and know about the system they are very useful. I have learned a lot about cables just reading about others opinions. We do not have the opportunity, time and resources to try every cable in our systems, some indirect knowledge can increase the efficiency of choosing significantly. It is great to have many opinions here of people we have been following since a long. BTW, reviews are just opinions emitted by a reviewer ...
