logo lamp out part 2
graystoke4
19
uk nottingham
hi you might remember part 1 ,, right i have taken the lamp cover off there are three small lamps on a small circuit board with the number 7382 printed on them,,NOW what do i or should that be what do YOU do, do you replace lamps with a soldering iron, or do you buy a new pcb from spectral,???, as im in england with no dealers, this will be a problem, does anyone know the cost of this board, or do i get my iron out , (if i had one) all information will be gladly received, thanks again andy,
nirodha
694
308
1,625
Don't know exactly how a friend of mine did it...but it did not take 30 minutes and no soldering was involved. Just a bit awkward to get at the screws.
Good luck.
DonH50
Jun 22, 2010
3,961
322
1,670
Monument, CO
The 7382 is a small leaded (i.e. has leads) incandescent bulb. While it could be soldered I really doubt it; more likely they are just stuck into small pin sockets on the board. Pull them out (gently) and replace them. The bulbs are available from Amazon, Digikey, etc. so a local electronics store may have them for you. I saw them from $0.50 USD to about $5 USD on-line (each).
Examples:
http://www.amazon.com/Eiko-40922-Miniature-Automotive-Light/dp/B002CYZIMM
http://www.amazon.com/Sylvania-3841..._sbs_hi_1?ie=UTF8&refRID=0G4T6JTQYBW039ZVN61Q
HTH - Don
graystoke4
19
uk nottingham
thanks for the advise don,, gave them a gentle pull and they came straight out, they looked like they were soldered in at the back, now will be ordering new lamps today,, cheers andy,,
Hourwerk
7
UK
Had mine replaced recently by my hi-fi dealer. Looks so much better with the lights on especially when listening at night!
