Krell HomeTheater Standard question
Johndi
1
Where I am using this preamp behind a front projector screen and unfortunately I have no option to move it.
I was wondering if there is something available that I could use, what I can it is a repeater, or some that can pic up the Krells remote signal and send it to the preamp at a different angle if this makes any sense? Or if anybody has any other ideas.
Thanks in advance
John
RBFC
WBF Founding Member & Super Moderator
Albuquerque, NM
www.fightingconcepts.com
#2
There are wired sensors that can plug into the Krell’s remote control port, with the receiving end of that sensor in sight of the user.
Lee
Members online
