That would be a big change in direction though!
yes...would go SE Tube for power, perhaps tube pre too. Tube pre's present a bit of a problem with some source gear being XLR connections.
I get it Christian . I wonder how many times you’ll actively choose not to spin an lp on the AS.
I guess choice is the spice of life for audiophiles.
David I understand Marc angst when you get your digital sound good, and then set up your vinyl, till you dial it in, you worry u won’t get the vinyl magic, I have experienced this myselfMost of us feel blessed to have this affliction but Marc has a lot of angst !
david
I have 7 arms spread over 3 tables, two phono stages with 3 inputs each. Clearaudio only table that does 78 and has a cool magnetic bearing design so it stays. AF1 has vacuum holdown and air-suspension so it stays. Those are features I like to have from time to time that the AS does not have. Can’t they all coexist ?
Currently I can’t get Vox Palladium off my brain after Davey started that thread and I the thought of the idea of new speakers in a couple years.That may be the next upgrade...Awful expensive though.
. . . Tube pre's present a bit of a problem with some source gear being XLR connections.
(...) Now if the argument is “I can, so I do”, then that’s where I’ll leave it, because Christian certainly can, and I certainly can’t.
But I can’t see why anyone would want to play lps on any tt decidedly worse than the flagship of flagships.
I certainly could get this if it was true that the AF1 does some things better than the AS.
when I had only one phono stage and it went down, I was without vinyl for a couple weeks. I'm a prepper, what can I say ?
after considerable pondering, I've decided to go 'nude' with the initial AS-2000 installation. and I've decided after speaking to David, that i'll be sourcing my support table from him. he is building his own dedicated steel topped and framed table. so for now, no active isolation with the Taiko Tana version of the TS-300 under the AS-2000.....but the new table will be easily able to support a TS-300 should I do that later.
If I had not talked to Jarek before, I would get the rack from David too. Simple, smart with good value. Big enough to put any anti-vibe platform on later. Gentleman enough David never pushed me into buying his rack. I also bought two 3012Rs from David to be used with AS. The third arm will be SAT which Marc Gomez is doing an armboard for me at the moment. I will put GFS, ZYX and Opus1 on these arms.
Tang
Tang, Are you still breaking in your MSL Signature Platinum? How does it compare to these cartridges? I'm especially curious about how it compares to the Opus 1.
