How to get S/PDIF from the MB
mep
17
All,
I have an Intel DP55WB MB that is the basis of my digital music server. I am currently taking the USB output and going into my EMU-101 DAC. However, the DAC will also accept an RCA S/PDIF input or a Toslink S/PDIF input. The Intel MB has a four pin S/PDIF connector on the MB where Pin 1 is ground, Pin 2 is S/PDIF + signal, Pin 3 is a key, and Pin 4 is +5V. What type of connector do I need to convert this into a standard Toslink or preferably RCA terminated S/PDIF connection so I can plug it into my DAC? Is the +5v for using Toslink? I would think with an RCA connection all I would need is Pin 1 and Pin 2.
Also, does anyone think using the S/PDIF connection from the MB is the better way to go rather than use the USB connection I'm currently using? Thanks.
Mark
DonH50
Jun 22, 2010
3,967
325
1,670
Monument, CO
Toslink requires an optical converter (and power). Using a simple header plug with pin 1 to shield and pin 2 to hot (center) into a coax cable and then RCA (or whatever) plug should work -- if, and this is a big if, you have a driver that will utilize the S/PDIF output! You may have to tweak the BIOS as well, although it is commonly enabled by default.
I have no idea if you'll hear any advantage. I suspect it's not worth the trouble...
This a guess from me; just noticed I am treading in Vincent's place and he'll have the "real" answer! - Don
mep
17
Don-Thanks for the reply. I found a cable on line that has the correct MB connector and is terminated with an RCA jack on the other end. I thought that S/PDIF signal had less junk riding on the signal than the USB connector. And since the S/PDIF connector is built onto the MB, it shouldn't be a big deal to turn it on assuming it's not already hot.
DonH50
Jun 22, 2010
3,967
325
1,670
Monument, CO
Well, the S/PDIF should be cleaner, but motherboards are not a low-noise environment so it may be a wash...
It shouldn't be hard to "turn it on" at the MB/BIOS level; it's the software drivers that may (or may not) be an issue. I took a look and it seems like Windows has some basic drivers so you may be fine (or, I may have drivers already from another application; I don't know for sure). Computer audio is not something I know a whole lot about so hopefully Vincent will step in and clarify.
I am very curious to know if you hear any difference! I have a couple of PCs in the house with that option so it would be nice to know if it helps.
All the best - Don
mep
17
Vincent-Your link is in German. For an RCA connection, all I need to do is attach the negative of the RCA jack to the negative terminal of the S/PDIF connector and the positive of the RCA connector to the positive pin of the S/PDIF signal correct? Do you think this will sound any better than using the USB input on my EMU-101 DAC?
Vincent Kars
WBF Technical Expert: Computer Audio
Jul 1, 2010
860
1
Looks like your German is as good as mine...
You have the pin layout correct.
I haven’t the slightest idea what the audible differences will be.
I hear very different reports about on board audio including SPDIF
It ranges from absolute crap to making an additional quality sound card obsolete.
Do a listening test if you get it all to work
Love to hear your results
Vincent
mep
17
Vincent-It shouldn't be hard to get it to work. Either my EMU-101 is a piece of junk and/or the USB interface from the computer is not very good. The sound of my lossless files on my hard drive is miles from the sound of my analog so something must be amiss. I will report back when my cable arrives and I get the S/PDIF working correctly and tell you if things got worse or better. Something has to give here.
mep
17
I keep calling my DAC the EMU-101 which was a mistake. It is the EMU-404.
Othersongs
15
Chicago-ish
Motherboard on board digital sound (via either S/PDIF coax wire (IMO/experience optical S/PDIF (aka Toslink) isn't quite as good) or USB wire, is as good as it gets (or close enough for me) for redbook sound (stereo 16/44.1); even compared to a high quality universal player like my slightly older Denon DVD-5910ci ($4k new).
My own recent experience is that the *quality* of mobo digital output (both S/PDIF and USB) varies from one recent mobo to another recent mobo. What is the experience of others on this?
