This is my first post here. I wanted to summarise 5 1/2 years of ownership and describe some of the frustrations as well as the very good.
I bought the Diablo 300 with the DAC module in 2016 after an audition of several heavyweight integrateds as I already knew about Gryphon and their reputation having heard Cantatas a long time ago. I also have the older Mojo loudspeakers so the Diablo looked like the perfect match. I wanted the DAC too after having heard the Scorpio CD player in anticipation of a good chunk of Calliope performance. So I breathed in and took the plunge.
From the point of view of sound qualityt it's by far the best integrated I've owned. All the hi-fi stuff is there - detail, soundstage, 3D imaging and speed but it also just gets out of the way of the music. I'm sure owners will no doubt concur with this. The DAC is also exceptional. Fed with a good quality signal (I'm using a DCS Network Bridge) every little detail is laid bare. I used to feed it through the USB input but found I preferred AES from the Bridge and I'm quite happy with 24/96 or 24/192. The Mojo's like volume and control but I'm often astonished by how good the system sounds at low volume. It didn't really take that long for the amplifier or DAC to reach stable operational performance either. So I would have no hesitation in recommending this amplifier to anyone who appreciates good sound and wants an integrated DAC. The dedicated sub out is very useful to as I also have an Audio Physic Rhea 2 for deep bass duty.
Now the irritations. Gryphon have made it very difficult to perform firmware upgrades. There is no exterior USB input and if the amplifier is within warranty it MUST be done by a qualified Gryphon technician or dealer. I've had it updated once and I remember it involved a special USB key. The top panel was removed and then a jumper from the main board which is actually quite tricky to do. The key was inserted into a socket on the board and the upgrade completed on a power cycle. The owner does not have a copy of the software so cannot roll it back in case of problems. The big issue for me is that the amp needed to go back to the dealer which is not a trivial task. I've also had a couple of operational issues. One is where the amp stops responding to the remote control although the relays click. And another where the display dims which makes it almost impossible to see. These issues happen very occasionally and can be reset by power cycling but other than that it's been faultless and the heat generated is a lot less than I expected although I would recommend at least four inches clearance from the top of the amplifier. I would also recommend that you do NOT use a power conditioner. Connect this amplifier direct to the wall socket preferably on a dedicated circuit.
My only other recommendation concerns the Mojos. Keep them away from the back wall toed in towards the listener as recommended by Gryphon. And go for the low setting on the resistors - 22Ohm at the top and 10 Ohm at the bottom. Happy days. The only negative is the original Mojo stands which are really quite poor for a premium product and if I was to replace anything it would be the stands. They do work if you fill them with sand or lead shot.
Qobuz sounds particularly good using this setup and I also have a QNAP NAS with SSD for local streaming. I find using a double router setup very beneficial.
I'm sure the Essence separates are better but I'm quite happy with the Diablo 300 and I've heard nothing else in the last five years that would persuade me to change. So unless I win the lottery I'm done.
