Genesis tweeter attenuator value
Puunda
8
Hi everyone.
Recently got myself a set old of Genesis 400 + center + sub.
The speakers have an attenuator on the back, and from what I can tell it controls the volume of the rear firing tweeter.
All the drivers work well, but I think the attenuator is faulty. When you turn it, there is no sound from the tweeters. When you stop turning, sometimes there's sound and sometimes there's no sound.
I want to replace the attenuator, but don't know the values.
I've tried measuring it, but not able to, since it normally shows open circuit.
I know there's no schematics for the 400, but I'm hoping there's enough knowledge out there to be able to allow me to find a replacement
I figure all I need to know is a resistance value, power rating, and log or linear
Can someone please help me suggest a replacement.
I can upload photos if that helps.
Thanks
andromedaaudio
8,501
2,843
1,400
Amsterdam holland
Indeed best is ask the company off course, but older equipment what hasnt been used for a while can have a bit of corrosion built up.
You can use contact spray for electronic contacts , see if you can spray inside the attenuator , wait a while and power it on.
Its cheap and simple and might solve it
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
www.genesisloudspeakers.com
You could try as andromeda suggested and use a contact cleaner like the CAIG Deoxit Pro Gold. However, if you measured an open circuit, the previous owner might have used it a lot, wearing it out.
I don't know what is used in the G400, but a 10W wire-wound 1 ohm linear pot should work. The Genesis tweeter is a 4 ohm ribbon (purely resistive) so the 1 ohm gives is a 3dB range.
Puunda
8
Thanks for that Gary.
I've been searching for a 10W wirewound 1 ohm linear pot, but not been able to find any. They all seem to be 1k, 10k, 1M etc. Am I searching for the wrong thing? Or is it a very specialised item?
carolkoh
Sep 17, 2010
907
226
955
Seattle, WA
Puunda - contact our customer service through our website : https://www.genesisloudspeakers.com/contact-us/
I am happy to send you one if you pay for the shipping / postage. :)
garylkoh
Sep 6, 2010
5,599
225
1,190
Seattle, WA
Errr...... our current pots might not fit the old G400. That speaker is over 20 years old, and if I remember correctly, the old G-III used a different size and type of pot than what we currently use.
But, like Carol said. If you pay shipping/postage we'll be happy to send one out to you.
Puunda
8
I have emailed Genesis through the web page but have got no reply.
I tried the form to 'Sales and Service' but was having problems with the page, so I send a message to 'General Inquiries' but so far still have got no reply.
Is there an email address I can send my request to? Or should I try the web page again?
Thanks
Puunda
8
I emailed a few months ago. I will do it again, as I was having problems with website.
I messaged asking about potentiometers for the my Genesis 200. Happy to ask about it here if it's easier.
