Because the swept-back wings on the G2.2 is just as effective as the narrow wings on the old Gen-II, but is very much more stable. Too many pairs of Gen-II have been destroyed because they fell over when the wings broke off the base! To make it more stable, then you would have to go with the massive footers of the G1, and the cost, etc. which then make them very much more expensive.
Rosewood veneer in sheets large enough to cover these wings are also difficult to come by and extremely expensive. The old-growth trees that will produce a veneer sheet 96" long by 10" wide are extinct.
Here's another pair of speakers shoe-horned in - a pair of G1.1's this time. Most of these were sold before I started insisting on giving them more space....... may be I should just let the customer decide. Some of these systems have worked very well.
He might not have a big room, but he sure has money.
The crazy thing, mep, is that this actually IS a decent sized room...look at how 'small' the equipment seems to appear along that back wall. Put a pair of XLFs or Q7s and there is plenty of room for coffee table, couches, racks of music. Its just that those speakers are monstrously big...7'2" tall and 41" wide...they eat up half the room you can see in the picture. When I stood in front of 1.1s in my friend's living room (which was really big...over 40' feet long and about 18 feet wide with 12' ceilings...i really came to appreciate they are another scale bigger than all the Focal Grande EM, XLFs, etc.
Hah!! good one, Gary. BTW, how close to the back wall will the main panels go? One of the nice things about your 4-towers is that you can place them one slightly in front of the other...taking up less horiztonal space. The thing is most setups have the panels a third into the room which eats everything up if its a living room. Whereas with a pair of XLFs you often place them closer to the corners and toe them in. And the subs often go on sides or corner again.
I understand dipole panels have little interaction with floor and ceiling...but also little interaction with side walls. How about the back wall behind the speaker? If you had 18' feet wide and fired down the long end of the room (35')...can you get the bass towers in the corner and place the panels 2 feet from the front of the towers so that you get 30' open space and maybe 9.5-10' horizontal clear space for equipment rack/screen?
Lloyd is right. The turntable in the corner is the massive Clearaudio Statement.
Thanks, Micro. Very true...was just wondering if there are some groundrules (like Dipoles apparently have) which might obligate panels to be far from the front wall...or conversely, where panels would work well within less than 4 feet from front wall.
