Focal Maestro Utopia AMP recommendation
pelo911
102
Houston , Texas - USA
Hi
my current system:
wireworld platinum usb cable
Pass labs X350.5
Pass labs Xp10 pre
Oppo BDP-105 using it as DAC
PC computer
can you recommend on few models i should demo?
looking for dynamic and matching for the big utopia
Thanks
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,484
1,012
1,320
He did Bruce but it dead ended rather abruptly. Even after bumping the linked thread on Nov. 18th, no replies came in. He went ahead and separated each request to a different thread in the apparent hopes to illicit more responses geared more toward each inquiry.
Tom
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Well the amp/pre are fine. What you should be putting your money in are things that will make the most difference.... like the room. I see no mention of any room treatments. To get something significantly better than the Pass, you would have to spend many thousands of dollars.
