I'm just getting around to setting-up a Dual 1019 which I acquired. The only issue I have with it is a static/crackling noise, on the speakers, when I use the auto-start function. As the tonearm moves the noise happens. There is no noise if I use the manual start method. Grounding it to the preamp made no difference. Any thoughts or suggestions will be appreciated.
