Dsd dac conversion by filter only
awsmone
1,616
514
435
Canberra Australia
I am interested in others views on this trend of dsd only dac by conversion "back" to analog by filter only with no dac chipset
That is it stays in dsm state till conversion by low pass filter
It seems ps audio and lampizator have gone this route with their recent designs. and I assume Meitner and Koch with their more expensive designs much earlier
I am not sure if this is what chord did as well
Although this possibility has always existed it seems this as an approach has gained wider popularity recently
Did the original dac on the sony scd 1 etc use a similar approach?
Is dsf downloads pushing this approach ?
Or is there technological change such as high power FPGA and programming making this a cheaper solution ?
Alrainbow
3,260
1,431
450
The questions you have might be answered in the ps audio forums. Ted the designer of the direct stream is on the forums there.ose questions as long as it's not downing the direct stream he should have some answers for you .
I own the direct stream and have a level 7 on order . The dire stream sounds very good on dsd . But the truth is most any dsd I tried that does dsd weather native or dsd over dop sounded really good. Although some were better but not like there was night and day .
Al
wisnon
3,536
640
1,200
Chord converts all to extremely high FS PCM. DStream goes through 3028mhz multibit PCM at one stage.
Only Lampi stays in DSD with no processing. Meitner/PBD/EMM stay in DSD too, but I understand they do lots of processing before analog output. Some Cirrus chips also say in 1 bit Dsd.
DonH50
Jun 22, 2010
3,966
325
1,670
Monument, CO
You need a high enough rate so the filter can provide enough noise shaping within the constraints of a passive filter design. Making a good filter is non-trivial, and passive or active has many of the same trades. Personally, I would want some sort of output buffer after a passive filter to reduce load sensitivity (I assume that is included in all these DACs).
