Devialet 400 Review
mauidan
1,512
11
36
Pukalani, HI
es347
35
1,620
Midwest fly over state..
Wow...hardly faint praise from a guy who's heard just about everything out there..
awsmone
1,616
514
435
Canberra Australia
I am a fan of devialet
my only criticism, which most reviews seem to miss is it works best in a digital source priority system
other than JA's review of phono
most others seem to not even discuss analog inputs
this meet be that they don't see buyers with analog sources
but would be nice to have comments on the ad da perfomance
if there are reviews discussing this please post links
thx A
mauidan
1,512
11
36
Pukalani, HI
thx A
http://www.stevehuffphoto.com/the-devialet-200-review-hifi-at-its-finest/
awsmone
1,616
514
435
Canberra Australia
Thanks Dan
But i see no mention of him using the analog inputs, other than the phono
This was covered as I said by JA
It also has several inaccuracies in it
Such as suggesting it goes from class A to D, which is not correct and misses the whole point of ADH output stage lol
" Called ADH®, for Analog Digital Hybrid, this patented topology connects a small, high-voltage, but low-power class-A amplifier directly to the speaker, with then a parallel class-D stage providing the necessary current. This is reminiscent of the innovative "current-dumping" circuit developed by Quad in the mid-1970s, though the Quad circuit used a class-AB current amplifier. However, the AHD circuit differs significantly in detail from Quad's, and is considerably more complex. Extraordinarily, there only two resistors and two capacitors in the analog signal path! " JA's description
Also it may take many MCs with different loadings, but its MM stage has some funny loading values ? what is high
"The D-Premier's phono input preserved absolute polarity (ie, was non-inverting) in both MM and MC modes. Set to MC, the highest choice of input impedance was 460 ohms; I measured 461 ohms. In MM mode, the highest input impedance is unhelpfully called "High." I measured 14k ohms at 20Hz and 1kHz, dropping slightly to 12k ohms at 20kHz. This might bit too low for Shure cartridges, which like to see 68k ohms. " From JA's measurments
This is probably more important than loadings for MCs !!!
So still nothing on the analog inputs
It also flies in the face of Alan Sircum saying the phonostage was good but not great
Having said that, I personally thought the phonostage very good( as did JA), and I think a posting saying the purity of the output stage and the short length of the signal path, made up for shortcomings in the ADC, of analog, being digitised which at 24/192 is probably pretty transparent anyway
Diapason
325
39
335
Dublin, Ireland
For what it's worth, when I had the Devialet 200 on loan I used the analogue outs from my Wadia to the analogue in of the Dev. This seems perverse, but I don't have the digital board on my Wadia and I really wanted to test how the Devialet worked as an amp. In short, I thought it was excellent, and despite the convoluted process of Digital -> Analogue -> Digital -> Analogue it remains the most transparent sound I've ever heard in my system. I had a very brief attempt at playing digital files from a laptop using the USB input and to my ears that lost a little something in comparison with what I've described above, but I had made no effort to get the best out of that setup so it can probably be disregarded.
In any case, I came *very* close to buying a Devialet purely as an analogue amplifier, and in many ways I regret not doing so.
f1eng
128
9
248
Oxfordshire
I bought a D-Premier about 4 years ago and added a second to make a dual mono a few months later.
I have tried the analogue inputs with FM tuner, Goldmund Mimesis 22 DAC, Goldmund PH2 phono stage and Revox B77.
I have tried the phono input both the MC input and MM using my Ortofon Jubilee and A90 both directly or via my T3000 transformer.
In my opinion the Devialet is the most transparent amplifier I have heard, whether analogue or digital inputs are used.
I am hoping to try the analogue input with one of the "idiosyncratically" designed DACs to see whether its character is transparently reproduced by the Devialet. I would expect so based on my experience with the other anlogue sources whose character was revealed clearly by the Devialet.
I had the D-Premiers updated to the new model and now have a Devialet 800!
I was in two minds whether to do it since I lost the HDMI input and the optical input spec is lower. Fortunately for me Devialet were able to fit a 24/192 optical input to one of my units so I effectively only lost the HDMI input.
There is a bigger power supply, more DSP capability and USB and ethernet inputs added, neither of which I have tried.
I have largely given up on streaming because of the inconvenience of using it with classical recordings so mainly listen to LPs and CDs.
The amp replaced a DAC/preamp/monos/cables which would cost perhaps 5x more if bought new today.
FrantzM
29
405
If I needed any more convincing ... ;)
4,702
Can we know what are your speakers?
f1eng
128
9
248
Oxfordshire
My main speakers have been Goldmund Epilog 1&2 since they were released. Last year I bought some Tune Audio Anima horns too. Neither made in sufficient quantity for SAM to be worthwhile for Devialet, and the Anima couldn't be measured in the way necessary either, apparently.
4,702
Thanks. You have the ancestors of the Magico Q series - FrantzM will be delighted to know and even more convinced!
