DCS Vivaldi
Elberoth
2,011
259
1,170
Poland
I think it was Map 1. No idea which filters has been used. That was a very brief listening, so I didn't have the time to explore the alt settings.
Elberoth
2,011
259
1,170
Poland
EML recti was weak with less bass and bloat as compared tohe special KR recti. Bill and I sold ours off immediately after listening to the special KR recti. Which is now what most like Christoph etc are using.
The 101D replicas are not good enough at this level. They are dynamic and detailed, but they lack tone, are lean, and are relatively flat planed as compared to the better valves.
I would suggest borrowing KR 242 (which, if it works with the gain, will jump performance up multi times), KR PX25, and the special Lampi EML 45s from Lukasz for a trial. Of the latter two, one or the other works better in most systems
I will need to try those.
Al M.
8,813
4,556
1,213
Greater Boston
Interesting. And that configuration is likely the most challenging for the Vivaldi. I'd try it with Dual AES from Aurender and the Vivaldi DAC I know needs to on for about 2-3 days to warm up properly and sound best...I'm guessing these two items may improve the "meat on the bones" aspect...
Regardless of DAC, AES/EBU is likely to give better results than USB of you have the choice, and proper warm-up for a few days is always recommended. So yes, I agree.
4,704
Regardless of DAC, AES/EBU is likely to give better results than USB of you have the choice (...)
The only reason I can think for such is that DAC designers and manufacturers are not able to deal with noise created by asynchronous transmission of data, because they cannot guess the timing and exact hardware characteristics of the sending machine.
The complete Vivaldi solution manages to solve them in most part by separating the units - the external clock synchronizes all units and the DAC communicates with other units via dual link AES/EBU channels. People who do not own the separate external clock can use the DAC clock output to synchronize the other units.
I own and have used the Berkeley Alpha USB- AES/EBU with some success - unfortunately it does not have a clock input to accept the DAC clock.
Enatai252
163
23
150
Pacific NW
Our settings are identical.....Interested to hear what the NUC/ROCK does sonically, if anything.......
here are the components used to build the NUC.
Intel BOXNUC7I7BNH NUC Kit
Samsung 960 EVO Series - 250GB PCIe NVMe - M.2 Internal SSD
Crucial 16GB Single DDR4 2133 MT/s (PC4-17000) DR x8 SODIMM 260-Pin Laptop Memory
my dealer installed the ROCK software and transferred over my library and Core registration. he put in my system today, i hope to listen tonight. the NUC is plugged into the same switch as the Vivaldi Upsampler with the NAS is my equipment closet close to the router. Rossini is in different room but connected to same network.
LL21
14,430
2,518
1,448
I don't know just yet. I need to listen more to draw any solid conclusions. I have certainly liked what I've heard - certainly enough to warrant further investigation. I've been in this hobby long enough to learn that it is not the things that you like at first listen are essential for long term music satisfaction. I may miss the uncanny palpability and midrange weight that GG provides longterm.
I need to get my Lampi up to spec before any further comparos. I'm leaving for 2 weeks in August for an Elbrus expedition (the highest peak in Europe), so will probably drop my GG to ?ukasz for updates then.
Look forward to hearing the conclusion of this interesting 'competition'!
4,704
I'm running the WE101D replicas and the Emission Labs recti.
I had both DACs connected directly to the D'Agostino Momentum Stereo - which is my main amp now. Vivaldi was set to 0.6V output, so most listening was done with 0dB to -6dB digital attenuation.
Are you going to drive D'Agostino Momentum Stereo directly? IMHO we need the preamplifier to get the best of it. I really like the Momentum Stereo a lot, but dislike the price of the Momentum preamplfier ...
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Elberoth
2,011
259
1,170
Poland
The Golden Gate has a built in analog preamp, so I have no desire to insert a second one inline.
4,704
Do you have any information on the topology of the output stage of the GG? What is exactly the model you own?
I'd investigate an ARC REF 6 to pair with the D'Agostino (+ Vivaldi).
I was glad when I read this report, because it validated the D'Agostino + ARC combo.
FWIW about 15 years ago I drove my Krell 750 mono amps with an ARC Ref 3 Series lll and the sound was terrific IMHO. That was back in the days when Dan was the man
4,704
Francisco (& Adam)
LA Audio Show 2017: D’Agostino muscle, Audio Research glow, YG finesse – an intoxicating mix
I see no reason the same combo wouldn't work great on Adam's Q3, or your XLF!
cheers,
alex
I have listened many times to the Momentum's driven by ARC REF5, even my REF40 in my system and the REF10. Good sound, no doubt. But when the Momentum preamplifier was inserted in the system, the coherence was such that electronics are not SS or tubes anymore, they just disappear. I noticed a similar effect when I had the ARC REF40/REF750 in my system. An hybrid preamplfier / amplifier combo can sound great, but most of the time have a clear and noticeable sound signature.
I remember Michael Fremer reported something similar in his Momentum's review.
bonzo75
22,650
13,686
2,710
London
The best Alexandria X2S2 I heard was with Momentum pre, power, and vivaldi stack, Jazzhead's friend in Mumbai. Despite having similar power Spectral 400 and VTL s450 could not do that to the XLF.
Elberoth
2,011
259
1,170
Poland
I have the Golden Gate balanced.
XCop5089
124
96
260
Winchester, UK
Careful Steve, Kingsrule will be along soon to remind you that this is a Vivaldi thread! :)
4,704
Yes, we should refer we have listened to the "Four Seasons" when posting OT in this thread ... ;)
jfrech
2,157
753
1,160
Austin
Worth a read:
http://highfidelity.pl/@main-759&lang=en
"The Network Bridge outperforms Rossini and by a large margin."
"The Stream 820 board was chosen because it offers wireless Wi-Fi and cable network connections. This is a newer model than the one used for Rossini – the latter feature Stream 800."
My VUP has the stream800 board in it. According the the version menu in the iPad app. I wonder if the VUP is about to go through another upgrade soon? I just asked my dealer...he happens to be visiting dCS in the UK in 2-3 weeks...
Kingsrule
1,444
704
1,430
It would be great if reviewer would physically look at both boards to see if they are interchangeable....
Looking at both boards on Stream Unlimited site, they look very similar....
4,704
Worth a read:
How can he compare the Network Bridge to the Rossini? The Network Bridge does not have analog outputs and the Rossini is a DAC ...
jfrech
2,157
753
1,160
Austin
I think he's plugging the network board via AES/EBU into the Rossini's inputs. Vs using the Rossini's ethernet input.
My dealer has a note into dCS for more info. And to see if a VUP update is on the way soon if this reviewers claims bear out to be true...
