DCS Vivaldi
MadFloyd
775
1,700
Mass
Is the RCA set to 6v when you thought you had it lower? If so, could this this... I'm at DAC sw version 2.01, and upsampler version 2.01 also...
On your iPad have you clicked the update button (while inside the dcs app)? If you click on the gear icon (upper right) then click on information, then on version, you'll see a check for updates at the bottom.
I'm on app version 1.4 ...
Is it even possible to have the RCA set to 6v while the balanced is 2v? As far as I know there's only one global setting for output voltage.
I don't think I've noticed the update button (or if I did it was when I first got my Upsampler and have since forgotten about it). I'll check it tonight.
Thanks!
Kingsrule
1,444
704
1,430
What network board version are u guys on ?
BTW 2.01 fixed the gain issues
MadFloyd
775
1,700
Mass
Network board is 307 here. Software is 2.01 and of course the app is 1.4.
RS232 certainly solved the communication issues. Totally makes sense in terms of the DAC since the Upsampler is the only thing connected to the network.
microme
12
Audener W20 vs dCS Upsampler + NAS(Roon)
I'm thinking about upgrading source device.
( I'm using battery powered PC as source. (Roon+Tidal))
The device that I'm thinking about for upgrade are Aurender W20 and dCS vivaldi Upsampler+NAS.
Both are very expensive for me so I can't buy both of them at the same time. (I have to choose one)
I'll be appreciated If any one shares some experience on these devices.
- I need Tidal and hopely Roon too
- sound quality is my primary concern
- currently I have dCS Vivaldi DAC and Master Clock
- I'm also wondering whether there are differences in sound quality between NAS running Roon vs NAS running UPNP server
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Well, if you need Roon, the Aurender's off then, as they don't support it, nor plan to support it.
cheers,
alex
4,704
Does anyone have experience with the Shunyata digital cables (AES/EBU and clock) in a DCS Vivaldi stack?
vindixon
12
6
910
Radnor, Pa
www.vincentdixon.com
You can run both Roon & Tidal directly from the Vivaldi Upsampler so you wouldn't need an Aurender. Connect the Upsampler to your PC, router or NAS using ethernet. You can also control volume on the Vivaldi DAC directly from the Roon app who using the Upsampler V2 which is handy.
microme
12
Thank you. Do you mean Vivaldi Upsampler + NAS is better than Aurender W20 for sound quality?
microme
12
I have Vivaldi DAC and Vivaldi Master Clock which are connnected with Black Cat's digit75 cables.
(I have been interested in Shunyata digital cables but I don't have any experience with them)
jfrech
2,157
753
1,160
Austin
No, but I've tried Cardas Lightning, Purist Proteous Provectus and Transparent. It's amazing what better digital cables can do...I am sure Shunyata's are excellent. Sorry not a direct answer...
jfrech
2,157
753
1,160
Austin
Oh my yes. The upsampler is a HUGE addition to your Vivaldi equipment. This is clearly the way to go. If down the road you want a simpler/better interface for digital files ...then get the Aurender. However, the vivaldi iPad app suits my needs just fine, just have to have a small bit of computer knowledge to set up the NAS. Also get a better ethernet cable (I use Transparent it's about $250)
microme
12
Oh my yes. The upsampler is a HUGE addition to your Vivaldi equipment. This is clearly the way to go. If down the road you want a simpler/better interface for digital files ...then get the Aurender. However, the vivaldi iPad app suits my needs just fine, just have to have a small bit of computer knowledge to set up the NAS. Also get a better USB cable (I use Transparent it's about $250)
Thank you for your advice.
Sorry to keeping asking though....
1) Do you mean that using dCS app+uPnP server is better than Roon running on NAS for sound quality in Upsampler+NAS scenario?
2) Why do I need USB cable when NAS is connected to Upsampler with ethernet via switch/hub and the Upsampler is connected DAC through dual AES/EBU?
MadFloyd
775
1,700
Mass
John, I'm also confused why you employ a USB cable. Can you explain?
jfrech
2,157
753
1,160
Austin
It's ok...details are important on this subject. And some here will not agree with me regarding Roon and sound quality..
1) But I prefer my NAS drive (Synology DS716 +II) running Minim Server (uPnP) with dCS app over Roon server running on the same NAS drive using the same Apple airport extreme router and Transparent high performance ethernet (2 cables - one NAS to router, other router to UPS)
2) Typo should have said ethernet vs USB cable...I just corrected it in my post above)
Don't get me wrong...Roon on my NAS sounds great. However in direct comparison in my system I prefer Minim Server on sound quality. Roon is soft sounding dynamics seem restricted. Obviously the Roon interface is NICE.
You will not regret the UPS. It's a significant step up in performance for PCM based files of all resolutions. As for DSD, I usually use the pass through mode to get it the DAC...
jfrech
2,157
753
1,160
Austin
MadFloyd
775
1,700
Mass
Not enough coffee yet ... meant to say ethernet :)
Ha! I've been there!
Out of curiosity, have you ever tried disabling the Upsampler (e.g. using Clone mode) and listened carefully to 44.1 material? There are some interesting differences.
jfrech
2,157
753
1,160
Austin
No but I'll try now. Guessing filter/upsampling differences?
For PCM material, I've been listening to UPS F2 to DXD, DAC F6 mapper 3
For DSD material I use F5 Mapper 1
MadFloyd
775
1,700
Mass
I mention it because it's worth experimenting with. I don't want to say what my perceptions of the differences are lest I bias you. :)
microme
12
Thank you for sharing your experience. I think I have to save more money for UPS+NAS :)
