Caelin,
I wonder if you can help clear up the issue of how to best hook up a Typhon to one's system? Your own web states specifically that it is meant to be plugged into a Triton. However, there is much anecdotal discussion on this forum that suggests it should go into either the wall duplex that is in parallel to one's power amplifier (i.e. no Triton in the that configuration), or into the duplex outlets that are on the back of the Triton, and NOT the specifically dedicated Typhon power receptacle on the Triton, as stated on your website. Any clarification would be appreciated.
To take this further, why not use the Cyclops similarly, that is, in parallel with the AC receptacle that powers one's amplifiers, rather than plug the amps into the Cyclops? After all, the Cyclops is mostly a NIC containing unit like the Typhon, correct?
Finally, if the general theme here is that NIC containing units provide their best service when used in parallel to AC outlets that power components, one might conclude that there would also be solid benefit from say, purchasing price effective used gear with NIC units, such as the older Hydras, and using them in a similar configuration. Of course, one would not get the full benefit of everything the Hydra may offer by going this route, but if one were already using a Triton and was looking for cost effective way of adding NIC containing gear to use in parallel, would that approach be a reasonable one?
I do not mean any offense, but you are highly regarded as an engineer, so I am looking forward to an engineering/scientific explanation rather than one that say, a marketing executive might provide.
Marty
Thanks
Marty
